2009 hyundai santa fe gls
perfectq12v
Posted: August 10, 2009 at 8:48 PM / IP Logged
Need wiring diagram/color codes for:
Alarm
Remote Start
windows w/sunroof
Platinum - Posts: 13,670
Posted: August 12, 2009 at 5:57 AM / IP Logged
Security
WIRECOLORPOLARITYLOCATION
BatteryRED & PINK(+)IGNITION SWITCH HARNESS
Ignition 1ORANGE(+)IGNITION SWITCH HARNESS
Starter 1GREEN(+)IGNITION SWITCH HARNESS
All Door TriggerORANGE(-)AT BCM MODULE UNDER DRIVER SIDE DASH
Domelight SuperBROWN(-)AT BCM MODULE UNDER DRIVER SIDE DASH
Trunk TriggerYELLOW/BLACK(-)AT BCM MODULE UNDER DRIVER SIDE DASH
Hood TriggerRED / BLACK(-)AT BCM MODULE UNDER DRIVER SIDE DASH
Alarm DisarmYELLOW(-)AT BCM MODULE UNDER DRIVER SIDE DASH
Alarm ArmGREEN(-)AT BCM MODULE UNDER DRIVER SIDE DASH
Parking LightsBLUE/ORANGE(-)AT VEHICLE LIGHT SWITCH
Posted: August 12, 2009 at 5:58 AM / IP Logged
Remote Start
Ignition 2RED(+)IGNITION SWITCH HARNESS
Accessory 1YELLOW(+)IGNITION SWITCH HARNESS
Anti-Theft TypeUNIVERSAL IMMOBILIZER
Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key SenseYELLOW(+)IGNTION SWITCH HARNESS
TachometerBLUE/ORANGE(AC)IN HARNESS IN PASSENGER KICKPANEL
MAY ALSO BE WHITE
Speed SenseBROWN(AC)AT DIAGNOSTIC CONNECTOR UNDER DASH
Brake LightsGREEN/ BLACK(+)AT SWITCH ABOVE BRAKE PEDAL
MAY ALSO BE GRAY/BLACK
Reverse LightsBLUE(+)IN HARNESS IN PASSENGER KICKPANEL
ALSO AT VEHICLE FUSEBOX
HornGRAY(-)IN HARESS AT STEERING COLUMN
Rear DefrostBROWN
THIS WIRE WILL ALSO CONTROL THE OUTSIDE MIRROR DEFROST IF EQUIPPED
Posted: August 12, 2009 at 5:59 AM / IP Logged
Doorlocks/Windows
Power UnlockGRAY/BLACK(-)IN HARNESS IN DRIVERS KICKPANEL
ALSO AT BCM MODULE UNDER DRIVER SIDE DASH
PowerLockBLUE/BLACK(-)IN HARNESS IN DRIVERS KICKPANEL
Driver Mtr UnlockORANGE(REV)AT MOTOR IN DOOR
Driver Mtr LockBLUE(REV)AT MOTOR IN DOOR
LF Window UpPINK(REV)AT MASTER WINDOW CONTROL SWITCH
LF Window DnWHITE(REV)AT MASTER WINDOW CONTROL SWITCH
RF Window UpGREEN(REV)AT MASTER WINDOW CONTROL SWITCH
RF Window DnGRAY(REV)AT MASTER WINDOW CONTROL SWITCH
LR Window UpBROWN(REV)AT MASTER WINDOW CONTROL SWITCH
LR Window DnPINK(REV)AT MASTER WINDOW CONTROL SWITCH
RR Window UpORANGE / BLACK(REV)AT MASTER WINDOW CONTROL SWITCH
RR Window DnBLUE(REV)AT MASTER WINDOW CONTROL SWITCH
Sunroof OpenORANGE(-)AT SUNROOF SWITCH
Sunroof CloseBLUE(-)AT SUNROOF SWITCH
2009 hyundai santa fe gls - Last Post -- posted image.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
