dei 508d , hornet 564t
one4waves
Member - Posts: 10
Posted: August 10, 2009 at 9:51 PM / IP Logged
I'm adding this field disturbance 2 stage sensor to my system. I know that the blue and green wires go into the multiplexed input (blue wire), but I'm not sure if I should ground the black to metal or to the ground-when-armed output of the alarm. I know if I'm using the voice module or separate siren chirp relay I should use the g-w-a output to turn the sensor off when the system is disarmed, but if I'm using it with the 564T only, which method is correct? Don't I want it to do the same thing?
mikvot
Gold - Posts: 1,043
Posted: August 10, 2009 at 10:20 PM / IP Logged
Either way will work fine....I typically just go straight to chassis ground with the black wire.
JWorm
Platinum - Posts: 2,208
Posted: August 10, 2009 at 10:34 PM / IP Logged
Either way should work. I've done it both ways. If you have it to the gwa, the sensor won't be on 24 hours a day forever. Make sure to diode isolate it from the starter kill.
one4waves
Member - Posts: 10
Posted: August 11, 2009 at 6:23 AM / IP Logged
I don't have a separate starter kill relay installed. Does that matter in relation to using the g-w-a output?
Another question: Does anyone know which wire on the double guard shock sensor is +? red or white?
Posted: August 11, 2009 at 9:13 AM / IP Logged
Red and connecting to GWA is better in theory, less battery drain but in practice the above answers are correct.
one4waves
Member - Posts: 10
Posted: August 11, 2009 at 9:53 AM / IP Logged
Thanks guys
one4waves
Member - Posts: 10
Posted: August 12, 2009 at 6:06 AM / IP Logged
So since a starter kill relay is not connected to the g-w-a output, there is no need for a diode, right? If there was another device connected there such as a window module, would I need a diode? If so, what color oe what value diode?
Please excuse my obvious inorance. My member status is accurate.
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
