wire colors ungo k20 into 2000 crown vic
johnoh
Posted: August 12, 2009 at 12:58 PM / IP Logged
Hi all,
I am told that since all I want to do is use a keyless remote on my 2000 Crown Vic (no keyless ability now, just power locks), I just need to connect the Lock, Unlock, 12v, and ground from the Crown Vic to the Ungo K20.  No idea if its really that simple but am willing to try.  I have access to the door wires by removing the switch panel on the door, and have made the following chart:
Wire function/K20 wire color/Crown Vic wire color
unlock/Blue&BLACK/ Pink&LightGreen
lock/Green&BLACK/ Pink&Yellow
ground/BLACK/ Black
power/RED / ?
Within the door I have the switch panel C503 as shown on this page http://www.p71interceptor.com/lightedswitches/
The lock/unlock wires are easy enough to locate on the harness, and there are several black ground wires, but I do not see a constant 12v wire there.  I found the 12v wire under the dash, but was hoping to avoid having to remove the door panel and also having to thread a wire through that rubber conduit between the door and chassis.  Thanks for any help.  Thanks
paidnfull
Copper - Posts: 125
Posted: August 12, 2009 at 4:55 PM / IP Logged
You can do all the wiring inside the car.  All the wires are found in the kick panel.  Makes a lot more since that way too, you don't really want the keyless module in the door.
What part of texas are you in?  We install them for 50 bucks
johnoh
Posted: August 12, 2009 at 5:23 PM / IP Logged
I took off the kick panel (the plastic piece to the left of my left foot when driving - is that it?), but there were no pink/lightgreen and pink / YELLOW wires that I need for lock/unlock
KarTuneMan
Platinum - Posts: 7,056
Posted: August 12, 2009 at 8:25 PM / IP Logged
You may not have the transmitter for keyless.... but the car more than likely HAS keyless entry.
In this case the locks are IN THE DOOR. Posative pulse, same colors (the keyless module is in the door!)
johnoh
Posted: August 12, 2009 at 9:23 PM / IP Logged
my car is a Crown Vic Police Interceptor.  It does not have a keyless module
KarTuneMan
Posted: August 12, 2009 at 10:44 PM / IP Logged
Well then there ya go! My info says "no keyless" locks are reverse polarity in the kick.
johnoh
Posted: August 13, 2009 at 7:22 AM / IP Logged
does the guide say what color they are?   Because  the door harness clearly has a pink / YELLOW and a pink/lightgreen wire, but the kick area does not have those colors anywhere
chev104275
Gold - Posts: 1,436
Posted: August 13, 2009 at 8:21 AM / IP Logged
i usually do those either in the door jamb boot or inside the door and they are 5 wire locks
lock is pink / YELLOW
unlock is pink/green
i would suggest inside the door less movement on the connections
paidnfull
Copper - Posts: 125
Posted: August 13, 2009 at 1:01 PM / IP Logged
It will def be five wire locks on the the police interceptor.  You can catch the wires coming from the door boot to the inside of the vehicle.  On the drivers side the e-brake might put you in a tight spot.  They should be pretty easy to find in the passenger kick.  You can run your 12v and ingnition over from the steering column, and mount the keyless module in the passenger kick or behind the glove box.  Make sure you fuse your wires coming from the column if your run is gonna be more than a few inches.
