starter kill astrostart 2100
dk7892
Member - Posts: 20
Posted: August 13, 2009 at 1:29 AM / IP Logged
How do you hook up the starter kill to an astrostart 2100 in a 1996 suzuki esteem. Thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: August 13, 2009 at 8:52 AM / IP Logged
Does your P4 have a light blue?  If so, cut the starter wire on the truck, to this wire (key side) connect the lt.blue.
To the other side connect the dark blue. starter kill engages when you arm.... also this works as anti-grind
