jl audio amp low voltage
gsbartender
Member - Posts: 9
Posted: August 19, 2009 at 7:54 PM / IP Logged
OK ..   I have a 95 civic 2 dr ex with two Jl audio amps.. one is a mono block which is pushing a jw audio w3 12 and the other a jl audio 300/2 pushing my infinity components. The mono block is fine but on the 300/2 watt amp the low voltage light is on.   what does this mean? and can this damage my amp or speakers?? I can take pictures to show if needed.. speakers sound great the amp feels pretty hot compared to the mono block as well.
Platinum - Posts: 13,670
Posted: August 19, 2009 at 8:02 PM / IP Logged
It is normal for the 2 channel amp to run hotter than it's class D counterpart.  Have you used a meter to see if the voltage is low at the amp?  Red meter lead to the screw that tightens the power wire connection.  Black lead to the screw that tightens the ground connection.  Check this with the amp playing at moderate level.
gsbartender
Member - Posts: 9
Posted: August 19, 2009 at 8:11 PM / IP Logged
ok ill give it a try.. any type of volt meter I need to get or just a cheap from radio shack? jl audio amp low voltage - Last Post -- posted image.
Posted: August 19, 2009 at 8:20 PM / IP Logged
Any volt meter will work.  Before you check the voltage at the amp, check it at the battery just so you will have a reference.
gsbartender
Member - Posts: 9
Posted: August 19, 2009 at 8:26 PM / IP Logged
I just put a new battery in it yesterday. The old one had a bad cell. So the input volt on the amp should be the same as the battery output?? I have have a splitter set up.. tsnumai red that splits to two 8 gauges I think if I remember correctly one going to each amp
Posted: August 19, 2009 at 8:32 PM / IP Logged
Without the meter, there is really no way to see if the voltage is low.  There could be a bad connection between the distribution block and the amp, or you could have a bad connection on the ground wire.
yimke
Copper - Posts: 417
Reference Kirchoff's law here
A law stating stating that the voltage supplied to a DC circuit must equal the sum of the voltage drops within the circuit.
You are probably experiencing a voltage drop somewhere between your ground/power path. A poor crimp connection, a poor distribution block connection could be the issue of any of these. Therefore it will not get the full 12.6volts.
gsbartender
Member - Posts: 9
Posted: August 19, 2009 at 8:38 PM / IP Logged
Im thinking it may be the ground connection.. It may have come lose causing it to have the low light ill check it tomorrow.. thanks guys.. keep a look out tomorrow because im a noob to wiring
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
