sub woofer basics
crowegreg
Member - Posts: 7
Posted: August 20, 2009 at 10:04 PM / IP Logged
I'm completing my car audio system, and I'm installing Kenwood's KSC-SW10 powered subwoofer. I drive a Land Rover Discovery II. Because of the size of the KSC-SW10, it will be installed in the back of the vehicle. Can you make any recommendations to take into account when I'm installing this unit? What direction should the speaker be mounted in reference to the vehicle? If I mount the speaker within an enclosure, how large of holes should be made for the sound to escape? Any recommendations would be appreciated!!
Platinum - Posts: 13,723
Posted: August 20, 2009 at 10:16 PM / IP Logged
http://www.kenwoodusa.com/Car_Entertainment/Subwoofers/Powered_Subwoofers/KSC-SW10
tracktor
Posted: August 24, 2009 at 8:43 AM / IP Logged
0n a 2003 grand caravan sport i want to put after market sterio deck in besides getting the adapter plate is there a coverter plugin from deck to wiring harnes that i have to have or can i do with out it
tommy...
Gold - Posts: 1,901
Posted: August 24, 2009 at 8:57 AM / IP Logged
It might help to start your own post...but...
Metra Electronics Corp. - 70-6502
sub woofer basics -- posted image.
Description
Chrysler 2002 - Into Car
Product Specifications
  • Plugs into car harness at radio
  • Power and 4/Speaker
  • 22 pin connector
Allows installation of an aftermarket radio using the existing factory wiring and connectors. No cutting of factory wiring is needed.
Product Notes for 2003 DODGE GRAND CARAVAN MINIVAN WITH 3.3L ENGINE AND STANDARD AUDIO SYSTEM
If the vehicle has the amplified Infinity system, The speakers must be replaced. There is an amplifier on each speaker.
M.E.C.P & First-Class
Wednesday, October 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
