Need wiring diagram for starter circuit
None2Slow
Posted: March 28, 2003 at 4:36 PM / IP Logged
 I need the diagram for the starter circuit for my 2000 Mustang GT. When I push in the clutch and turn the key, nothing happens. No click or anything. If I turn the key to the run position and jump the pink wire under the hood, it cranks and starts fine. Once it starts, it can be driven fine. Any help is appreciated.
A computer once beat me at chess, but it was no match for me in Kick Boxing.
auex
Platinum - Posts: 5,041
Posted: March 28, 2003 at 9:05 PM / IP Logged
Honestly from reading this and your other posts it sounds like there is a loose connection somewhere. It COULD also be a fuse that you haven't checked yet. There are fuses that contol other fuses and the ones you checked may be fine but the other one may be bad. Just to rule this out, how did you check the fuse,pulled it out or did you use a multimeter(being that there are multiple power circuits out check with multimeter,or test light, and if you have at least 12.0 V then you should be good)? If you have the box fuses(1/2 inch by 1/2 inch or close to it) then look very carefully because it is hard to see a break in these type of fuses. The next step would to be to check all of the wire harness plugs in the kick panel and at the main fuse box under the hood and under the dash. As for the starter it may be a faulty switch at the clutch pedal. I would also pull the underdash and see if the starter wire has power when cranking. But like I said with this many things going out it could be a loose plug somewhere.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
