2001 Dodge Ram 2500 Diesel Alarm Wiring
quietken2000
Posted: August 24, 2009 at 6:18 PM / IP Logged
Please Help if anyone can.
I removed the alarm from my old chevy at trade in time and now have a 2001 Dodge ram 2500 Cummins Turbo Diesel.
I Really need the install manual for my alarm its a Autopage RS-662
And need to know what wires are what up under the dash.
CAN ANYONE HELP??
THANK YOU Very much in advance.
t&t tech
Platinum - Posts: 2,622
Posted: August 24, 2009 at 7:07 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 2001 / Keyless Entry
[PRINT THIS PAGE]
12volts      red and pink/black       +       ignition harness
Starter      yellow       +       ignition harness
Ignition      dk. blue       +       ignition harness
Power Lock      ORANGE / purple       5wi      driver door harness
Notes: Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.
Power Unlock      pink/purple       5wi      driver door harness
Lock Motor      ORANGE / black             driver door harness
Unlock Motor      pink/black             driver door harness
Parking Lights+      BLACK / YELLOW             headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger      yellow       -       headlight switch or DKP
Notes: To avoid dome delay, use tan for the drivers door and BLACK/ lt. blue for the passenger door. Both wires are located at the central timer module to the right side of the steering column. Use both wires and diode isolate each.
Dome Supervision      use door trigger
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm      lt. GREEN/ orange       -       driver door harness
Notes: Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger through a 1.5K (1500) ohm resistor. MUST use relays.
Factory Alarm Disarm      same wire
Disarm No Unlock
Horn Trigger      BLACK/ red       -       steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
No      Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information
t&t tech
Posted: August 24, 2009 at 7:09 PM / IP Logged
Those schematics are for the 1500 ram, but thay can give you a basic foundation for testing!
P.S on a side note! Do not create multiple threads about the same thing!
