I'm not sure if I'm doing something wrong or not. I've got an older DEI Hornet 574 Remote Start alarm system in my truck and since putting in I've had random "non-function" of the domelight. I'll disarm the truck and open a door (doesn't matter which one, sometimes even multiple doors open) and the domelight will not come on. Since I've got the "door trigger" on the BK/LB domelight wire, the alarm doesn't know a door has been opened and it will rearm (auto arming enabled) unless I notice the domelight issue and manually turn it on from the headlight switch. This doesn't happen all the time, not even most of the time, but often enough to be very annoying. It also makes me wonder if it's possible that a crook could open a door without triggering the alarm. Here are some alarm facts in addition to the problem description above, I just don't know what to make of this truck or where to go next to make sure it always works like it should.
1. "Door Trigger" is on the BK/LB wire exiting the instrument cluster. This is the main relay output for the domelight according to my wiring diagrams book for this truck. When the domelight does come on, the alarm does detect it correctly. Several online wiring references for alarms in this truck say to use the same wire color but pick it up in the kick panel. Is there any good reason why my location is a problem?
2. I armed my alarm and waited almost 10 minutes...the inside door lock button will still unlock the truck. This would seem to indicate that I don't need a GEM WAKE-UP for this truck. Just to be save, I installed one today but I can't tell yet if the problem has gone away. According to the GWA diagram, doing this will cause the domelight to activate when unlocking the truck...it does not??? I access all 3 of the necessary wires for the GWA right at the plug on the vehicle security module rather than at the door boot...not sure why it would matter but wanted to make that clear.
3. Lock and Unlock functions work perfectly. Until today I didn't know that I should use DOUBLE PULSE UNLOCK, so up until now it's always been single pulse. I did change it today so maybe that will help the situation?
4. The GWA diagrams got me thinking. It says that the door triggers REST AT GROUND, PULSE TO 12V+ AND RETURN TO GROUND WHEN OPENED. If that's the case, why are we breaking ground on that wire to wake the GEM instead of pulsing a 12v+. It would be really easy to do, swap the latch side (blue wire in diagram) to the 87a post, the GEM side (red wire in diagram) to the 30 post and jumper the 12v+ constant from 86 to 87. Whenever the keyless module pulses ground on 85, a 12v+ pulse will hit the door ajar wire of the GEM...wouldn't that work better and be more like opening the door or is there a good reason not to do that?
The dash is still torn apart in this truck, I'm hoping to get some good input before I put everything back together. I'm NOT an expert in this stuff by any means, but I'm smart enough to understand how things work and that's why I'm so annoyed that the stupid domelight acts this way.
Thank You very much for your time!!!!!!!!
