damaged clifford wizard serial port
i-vtec
Member - Posts: 23
Posted: August 30, 2009 at 6:13 PM / IP Logged
i was rushing and didnt notice i need a male to female adaptor etc. So i pulld the serial port side of the cable and damaged it.
Does and one have a wiring diagram for the interference circuit, so i can wire a new cable 2 it,and can i use a usb cable,
Its a 3 wire.
Please email me as its my first time on here,
i.vtec@hotmail.co.uk
Thank you
Posted: August 30, 2009 at 6:15 PM / IP Logged
No and that will teach you not to use Wizard.  It takes years of using Wizard Pro to seriously screw up your alarm.   Frankly it's quicker and safer to programme manually.
i-vtec
Member - Posts: 23
Posted: August 30, 2009 at 10:47 PM / IP Logged
im confussed.
Why is it difficult, i find it hard programing manually.
I will get a new serial port lead and solder wires on da clifford interference device.
Has any one have a basic guide on how to use the wizard program.
Posted: August 31, 2009 at 2:54 AM / IP Logged
No, you can't use a USB, if you find it hard manually programming, please don't try Viper or the latest Cobra.  I can assure you that Wiz Pro programming, and there are about 3 versions all work better with different versions. But they are all heavily glitched, try to programme crank time or tach on a G5 unit, it wil either not store or you will find all your papameters have changed, such as you now have passive arm and lock, hence my previous comment about years of experience.
They never issued a guide to programming and what did you mean by "da Clifford interferance device"?
i-vtec
Member - Posts: 23
Posted: September 01, 2009 at 4:19 AM / IP Logged
pm'd you howie
