underpowering subs?
livinloud247
Member - Posts: 33
Posted: August 31, 2009 at 1:24 PM / IP Logged
Will underpowering subs do anything to their performance? Will they sound bad?
I'm looking to maybe push the RF P3 shallow mounts, 10's or 12's with the Kenwood KAC-X10D Amplifier. It would push 300 rms to each sub. This is exactly what the 10's ask for, but what about pushing 300 out of 400 rms to the 12's?
DYohn
Moderator - Posts: 10,741
Posted: August 31, 2009 at 1:54 PM / IP Logged
It will make them play at less than their max SPL capability.  That's it, as long as the amplifier gain is set correctly.
livinloud247
Member - Posts: 33
Posted: August 31, 2009 at 4:17 PM / IP Logged
Ok, and what would you recommend setting the gain to based on rms from the amp to rms handling power on the subs?
DYohn
Posted: August 31, 2009 at 6:37 PM / IP Logged
I recommend setting the gain to match the output level from your head unit.  At 300 watts max it is not going to harm the subs as long as it is not clipping.
https://www.the12volt.com/installbay/forum_posts.asp~TID~85479~PN~1
