re audio, good, bad, opinions
the fat kid
Member - Posts: 35
Posted: September 21, 2009 at 8:35 PM / IP Logged
hello there, im looking to upgrade my system im currently running 4 diamond audio d1 10s on a diamond d3 1100.1, kinda kicking around the idea of going to 4 12s looking at the re se-x 12s, but i havent seen or heard anything about them except for the xxx's. any subs i should be looking at that are comparable? and lastly whats a good 2500 or 3000 watt amp to run these things, ive got a hifonics 600 watt in my tahoe and it does fine but idk how their high wattage amps are.
oh i forgot its going in a single cab 08 dodge ram. dont think thatll matter much though, bout to build a downfire box so i wont be so limited by mounting depth.
thanks in advance
ianarian
Copper - Posts: 516
Posted: September 22, 2009 at 7:13 AM / IP Logged
How much enclosure volume do you have to work with? On the side, is the current config going to support this change? Or are you going to have to replace all the power wiring too?
This is what I do for FUN!
the fat kid
Member - Posts: 35
Posted: September 22, 2009 at 11:40 AM / IP Logged
new wiring will go in 0/1ga and im sure ill have to add another set of components , i have 4 to 4.5 cubes if i go downfire with roughly 9 or 10 inches of mounting depth room
the fat kid
Member - Posts: 35
Posted: September 22, 2009 at 11:41 AM / IP Logged
also planning on adding a high output alternator, is a capacitor necessary if i do the alternator?
whiterob
Copper - Posts: 351
Posted: September 24, 2009 at 2:59 AM / IP Logged
No, do the big 3 though (see sticky).
the fat kid
Member - Posts: 35
Posted: September 24, 2009 at 10:59 PM / IP Logged
definatley plan on it, thanks.
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
