02 f250 diesel wait to start
blitzdemon
Member - Posts: 7
Posted: October 06, 2009 at 10:29 PM / IP Logged
installed a viper 791. tech sheet said to use programmable wait-to-start (10, 15, or 20seconds).
customer is having issues with it not starting on the first or seconds attempt.
why cannot go to the glowplug light in the dash to use for my wait-to-start? i got it programmed to the lowest setting which is 15seconds...should i maybe snag a bitwriter to get it down to 10seconds?
he also says that when it does remote start that it idles at like 1000-1200rpms but when he presses the brake to disengage the r/s it idles back down. i solder all my wires (including tach).
ckeeler
Gold - Posts: 1,461
Posted: October 06, 2009 at 11:03 PM / IP Logged
you cant use the glow plug light in the dash because the light is done by data. if the customer is having a hard time getting the truck to start at 15 seconds, you dont want to go to 10, you want to go to the next highest setting, 20seconds. this will allow the glow plugs more time to get hot enough for a start.
blitzdemon
Member - Posts: 7
Posted: October 06, 2009 at 11:19 PM / IP Logged
if i set the timer for too long will the glowplugs eventually time-out/shutoff?
ckeeler
Gold - Posts: 1,461
Posted: October 06, 2009 at 11:26 PM / IP Logged
yes eventually, but it is more likely to result in an engine start that way rather than going the other way, or just leaving it at 15 seconds.
Moderator - Posts: 12,488
Posted: October 07, 2009 at 9:22 AM / IP Logged
It's not even cold outside yet, sounds like there's other issues other than the glow plug timer.
ckeeler
Gold - Posts: 1,461
Posted: October 07, 2009 at 9:33 AM / IP Logged
that sounds completely possible.
blitzdemon, what are you using for a tach signal?
blitzdemon
Member - Posts: 7
Posted: October 07, 2009 at 11:24 AM / IP Logged
got tach from GREEN / WHITE wire in 5pin harness that was taped up behind parkbrake release.
he's got a EDGE programmer in there also, that wouldnt have anything to do with the issues at hand would it?
Posted: October 07, 2009 at 11:32 AM / IP Logged
Use the alternator sense wire on that truck instead as I've had problems using that GREEN / WHITE wire under the dash in the past.
blitzdemon
Member - Posts: 7
Posted: October 07, 2009 at 11:42 AM / IP Logged
where/what is the alt sense wire?
or should i use -
''On diesel vehicles the tach wire is green or white, in a 42 pin plug under the clamp on the engine side of the air intake duct.''
blitzdemon
Member - Posts: 7
Posted: October 07, 2009 at 11:44 AM / IP Logged
blitzdemon wrote:
where/what color is the alt sense wire?
or should i use -
edit
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
