pac tr 7
turbodx
Member - Posts: 10
Posted: October 08, 2009 at 8:44 PM / IP Logged
I just bought a used IVA-D901 and it is already prewired with the Pac TR-7 , I'm trying to install the NVE-N852A ( alpine Navi ) , my question is do I connect the wire for the reverse (comming from the navi) to the PAC and if so which color wire on the PAC do i use ?
turbodx
Member - Posts: 10
Posted: October 08, 2009 at 8:45 PM / IP Logged
2001 Toyota 4Runner SR5
KPierson
Platinum - Posts: 3,527
Posted: October 08, 2009 at 8:53 PM / IP Logged
What exactly is the function of the tr 7?
I think I already know the answer, but want to make sure before I post anything.
Kevin Pierson
Platinum - Posts: 13,672
Posted: October 08, 2009 at 9:15 PM / IP Logged
The only purpose of the reverse wire is to keep the nav display from flipping upside down when you back up.  It should not be connected to the TR-7
turbodx
Member - Posts: 10
Posted: October 09, 2009 at 6:19 AM / IP Logged
cool thanks , the HU brain itself has a wire that needs to be connected to the reverse , can anyone tell me where to find the reverse wire in an automatic 2001 toyota 4 runner ?
I did go to the install ay and found the color code for the wire , i just don't know where to locate it.
Posted: October 09, 2009 at 6:22 AM / IP Logged
It should be in the harness of wires that goes from the drivers kick panel to the rear of the car.  remove the kick panel or the drivers door sill.  It should be in both of those locations.
