2008 F-150 Python 1400xp Sattelite Wiring
angel padilla
Member - Posts: 6
Posted: October 13, 2009 at 9:38 AM / IP Logged
 I need the wiring sequence on the sattelite box and where is connected. Can anybody help.
t&t tech
Platinum - Posts: 2,621
Posted: October 14, 2009 at 5:03 PM / IP Logged
If it's the xcrs you are  reffering to
The three fused wires connect to a proper 12volt source, at the main ignition harness would be fine
green- cut your true starter wire and this connects to the side from the keys
purple- to the other side of the cut wire
pink- to true ignition wire
pink/white- second ignition in car
orange- accesory wire in car
Did i omit anything?
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
