2001 ford mustang
bravokyd
Posted: October 20, 2009 at 1:15 PM / IP Logged
2001 ford mustang wiring diagram?
does anyone have one?
thanks
bravokyd
ceasar326
Copper - Posts: 239
Posted: October 20, 2009 at 2:54 PM / IP Logged
  FORD
 MODEL YEAR(S)
 MUSTANG  1999 -2004
 KEY T-HARNESS IMMOBILIZER
  FD KEY-1   FD-1   FORD'S PATS ANTI-THEFT SYSTEM, TRANSPONDER, Requires 791 and Extra Ignition Key
 PART  COLOR LOCATION
 12 VOLT CONSTANT  YELLOW (+) and LIGHT GREEN/ PURPLE (+)   IGNITION SWITCH HARNESS
 STARTER WHITE/ PINK (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 RED / LIGHT GREEN (+) IGNITION SWITCH HARNESS
 IGNITION 2 RED / BLACK (+) IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 GRAY / YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 BLACK/ LIGHT GREEN (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) BROWN (+)  @ GEM, 26-Pin Plug, Pin 7, See NOTE *1
 POWER LOCK LIGHT GREEN (TYPE A)  @ GEM, 20 Pin Plug, Pin 20, See NOTE *1
 POWER UNLOCK PURPLE (TYPE A)  @ GEM, 20 Pin Plug, Pin 18, See NOTE *1
 DOOR TRIGGER YELLOW/BLACK (-) and GRAY/RED (Right) (-) Use both, See NOTE *2  @ GEM, 20 Pin Plig, Pins 13 and 5, See NOTE *1
 DOMELIGHT SUPERVISION BLACK/ WHITE  @ GEM, 20Pin Plug, Pin 3, See NOTE *1
 TRUNK RELEASE PINK/LIGHT GREEN (-)  @ GEM, 26 Pin PLug, Pin 25, See NOTE *1
 SLIDING POWER DOOR N/A
 HORN YELLOW/LIGHT GREEN (-)  @ GEM, 26 Pin Plug, Pin 12, See NOTE *1
 TACH Any wire that is NOT RED or WHITE/ LIGHT BLUE  @ any IGNITON COIL or FUEL INJECTORS
 WAIT TO START LIGHT N/A
 BRAKE RED / LIGHT GREEN (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  DARK GREEN/ PURPLE (-)  @ GEM, 20 Pin Plug, Pin 16, See NOTE *1
 ANTI-THEFT FORD'S PATS ANTI-THEFT (Some Vehicles) TRANSPONDER SYSTEM  TRANSPONDER @ IGNITION SWITCH TUMBLER
 EXTRA INFORMATION
 NOTE *1 The GEM (Generic Electronic Module) is located ABOVE the DRIVERS KICK PANEL. NOTE *2 This vehicle has 2 Door trigger wires at the GEM Module, when connecting to an ALARM SYSTEM,use both DOOR TRIGGER wire and DIODE ISOLATE, to connect, See DIAGRAM.
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
