2009 volkswagon jetta
craziecracker
Member - Posts: 6
Posted: October 23, 2009 at 1:11 AM / IP Logged
need wiring for a remote start for a 2009 volkswagone jetta, its got sunroof and power windows, its the city jetta. thanks in advance
Posted: October 23, 2009 at 1:45 AM / IP Logged
Do a search, this topic came up a couple of weeks ago. Don't even consider this without a CAN adaptor.
craziecracker
Member - Posts: 6
Posted: October 23, 2009 at 1:52 AM / IP Logged
was planning on using an omegalink bypass. should cover all of that.
craziecracker
Member - Posts: 6
Posted: October 23, 2009 at 1:55 AM / IP Logged
the wiring on the cars is the same as the 07's?
Platinum - Posts: 12,488
Posted: October 23, 2009 at 7:56 AM / IP Logged
Yes, nothing really different about this other than it's called a City Jetta. You will still need to loose the valet key to the remote starter in a universal key in the box. Very easy vehicle to install into.
metz35
Copper - Posts: 458
Posted: October 23, 2009 at 8:56 AM / IP Logged
Remote Start/Security 2009 Volkswagen City Jetta 4DR Sedan
Remote Start/SecurityRemote Start/Security
Function Equipped Type     iC
PASSIVE ANTI-THEFT   YES TRANSPONDER
Wire/Function Colour Location/Description Polarity
iC
12 VOLTS   Red At fuse/junction block below dash +
IGNITION   Yellow On back of ignition switch +
Remove the plastic cover around the steering column and you will see a small black box mounted to column held by 1 torx screw. Remove this box to expose the ignition key wires, they are all 22 gauge.
ACCESSORY   Green On back of ignition switch +
STARTER   Red On back of ignition switch +
KEY SENSE   Blue On back of ignition switch +
Not required for remote start.
TACH SIGNAL Use a fuel injector
DIESEL TACH SIGNAL Tan/green SEE NOTES
Remove the cover over the battery and you will see 2 harnesses against the firewall. The wire is located in one of the 2 harnesses.
FUEL INJECTOR   Opposite from RED / black At any injector on engine AC
LOCK   BROWN / green At module in driver's door -
One wire system uses straight ground to lock/arm and ground through a 1200-ohm resistor to Unlock/Disarm (double pulse to unlock all doors).
UNLOCK   BROWN / green At module in driver's door -
ARM Arms with lock wire
DISARM Disarms with unlock wire
GLO-PLUG SIGNAL   DATA ONLY Use a 15 second start delay
DOMELIGHT / ALL DOORS RED / yellow At light under dash -
HOODPIN   BROWN / red At pinswitch in engine compartment -
TRUNK RELEASE   Blue At switch in driver's door -
BRAKE SWITCH   BLACK/ red On fusebox or in driver's kickpanel +
PARKING LIGHTS   SEE NOTES
Parklights require some special wiring, please see the provided diagram.
PARKING BRAKE BROWN / yellow At switch on parkbrake lever -
DRIVER WINDOW UP   Extend lock pulse to roll-up windows
DRIVER WINDOW DOWN   Extend unlock pulse to roll-down windows
PASSENGER WINDOW UP   Extend lock pulse to roll-up windows
PASSENGER WINDOW DOWN   Extend unlock pulse to roll-down windows
REAR DRIVER WINDOW UP Extend lock pulse to roll-up windows
REAR DRIVER WINDOW DOWN Extend unlock pulse to roll-down windows
REAR PASSENGER WINDOW UP Extend lock pulse to roll-up windows
REAR PASSENGER WINDOW DOWN Extend unlock pulse to roll-down windows
HEADLIGHTS   WHITE/ black At light switch in dash +
