parking lights
bat9905
Copper - Posts: 131
Posted: November 09, 2009 at 11:01 PM / IP Logged
Hi. Thanks for all the help the site is great. I have a issue with trying to get the parking lights to flash. I have a 2001 nissan pathinder and for some reason i can't seem to get them to flash. I located a wire that is pink with black in kick panel. It shows 12 volts when parking lights are on. When i shut them off it goes to 0. I figured hooking up the white wire off Prestige APS 920A
which is labeled parking light output should work. Nothing happened. Is there something i'm doing wrong. Thanks for any help
        Brandon
bat9905
ckeeler
Gold - Posts: 1,461
Posted: November 09, 2009 at 11:32 PM / IP Logged
are you actually getting 12v from the white wire? is it a positive output, or negative?
bat9905
Copper - Posts: 131
Posted: November 10, 2009 at 8:49 PM / IP Logged
No sorry what i meant was the the pink with black wire was in kick was getting 12 volt but I think I figured it out. Off the unit i was supposed to hook up white with red traced wire to 12 volts and the white wire to pink with black in kick and it should work. I actually read the installation manual. Lol. Ill let you know if i have any more problems. Thanks
bat9905
