01 caravan 2nd starter
bruc007
Copper - Posts: 74
Posted: November 19, 2009 at 11:56 AM / IP Logged
I've read most posts here on this matter and am still not completely
clear on the wiring .The Prostart unit has a 2nd starter wire +.Could someone post the exact wiring for the relay and position of the resistor.The wiring schematic from autostart is more complicated I think
http://autostart.ca/Autosoft/images/RelayDiagrams/19078.pdf
Thanks,Bruce
Mike M2
Platinum - Posts: 2,652
Posted: November 19, 2009 at 4:11 PM / IP Logged
This is a little more complex than it needs to be but will work. If the key has a black plastic head you cen omit the diodes alltogether...
http://documents.audiovox.com/700820.pdf
Mike M2
Tech Manager
CS Dealer Services
