dei 520t and clifford 850i alarm
7rrivera7
Member - Posts: 17
Posted: November 21, 2009 at 7:35 AM / IP Logged
To use the 520T, does the alarm brain need a dedicated backup battery input or can I connect the brain's, 2 Red and RED / White Constant Power Input wires to the 520T's Grey wire?
I wired it up and it works fine except I'm concerned about the significate difference in 12v wire gauge on the 520T (small) vs the alarm brain (thick).
Since the 520T is always "in-line" with the alarm's 12v input, it (520T) is always providing voltage to the brain, even when triggered normally, i.e., even when the trigger is not the disconnected car battery.
Hope I explained myself...
7rrivera7
Member - Posts: 17
Posted: November 21, 2009 at 7:53 AM / IP Logged
Correction: the alarm is a Crime Guard 850i, not a Clifford.
My research is telling me I can't (shouldn't) use the 520T with my brain as the power inputs are 30amps, necessary for the remote start capability.
Even if I don't use the remote start capability, is it still a bad idea to use the 520T with my alarm?
7rrivera7
Member - Posts: 17
Posted: November 21, 2009 at 6:53 PM / IP Logged
Anyone?
t&t tech
Platinum - Posts: 2,622
Posted: November 21, 2009 at 7:26 PM / IP Logged
Only connect the red wire of the alarm supply to the brain to the 520t's grey wire, the other heavy gauge remote start wires are to be connected to a good source of twelve volts!
