08 nissan sentra, viper 5701
tonkatoyota
Member - Posts: 7
Posted: November 27, 2009 at 11:04 PM / IP Logged
Doing a viper 5701 on a 08 Nissan Sentra. So far, all of the wiring diagrams I have used on here have been partly incorrect. Door pins, etc. Thats just the way it is I guess? I'm trying to find the parking lights (+). Can't find them. Will they be big wires, or small wires.
Also if anyone has an accurate wiring diagram, shoot it over.
Thanks from the newbie,
tedmond
Gold - Posts: 4,610
Posted: November 28, 2009 at 6:27 AM / IP Logged
Parking LightsRED(+)IN HARNESS IN DRIVER KICKPANEL
thats the info i have for it, give it a shot. the wire will ravy from car to car. usually i find them to be 12-16 gauge wires.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 28, 2009 at 7:49 AM / IP Logged
Red wire , grey plug on the right corner of the fuse box. Its the wire just ABOVE the clip for the plug!
HEY TED!
tonkatoyota
Member - Posts: 7
Posted: November 28, 2009 at 7:40 PM / IP Logged
I found the wire... Red with a blue stripe. Gray connecter behind the fuse box. It wasn't red.
Thanks for the help. We should update that diagram...
tonkatoyota
Member - Posts: 7
Posted: November 28, 2009 at 7:44 PM / IP Logged
Just insalled a viper 5701 and the brain isn't resonding to anything. All wires are connected like they should be. I tested +- , the whole deal. Am I missing a step to get it to work? I've tried the remote control learn and nothing. Please help!
Thanks,
Newbie
tonkatoyota
Member - Posts: 7
Posted: November 28, 2009 at 11:14 PM / IP Logged
I'm having trouble with the factory alarm. What do I pulse to disable it? That BCM is way up there dude, I bet there is an emoty oin up there or something. But which one? Please help, again. LOL
tonkatoyota
Member - Posts: 7
Posted: November 29, 2009 at 9:34 PM / IP Logged
Okay, I know I'm like triple posting here, but almost finished with install. Still some questions, couldreally use the help. Trying also to pass along some usefull info that might prevent someone from killing their whole weekend trying to do an install with the wrong wiring info.
My review of post for an Install of a Viper 5701 in a 08 Nissan Sentra:
Couldn't find paring lights pos ; Diagram said (red). Found them, they were (RED / blue) Back of grey connecter in drivers kick
Brain wouldn't resond- Didn't have the antenna hooked upcorrectly. Doh!
Door triggers were wrong wrong in every diagram; driver f (blue) driver r(red white) pass f (red white) pass r (brown white) are correct
Trunk trigger; violet 12 pin connecter next to the 40 pin at bcm
My install is almost complete, 2 more issues...
Where can I send a (-) pulse to disarm the factory alarm??
I now have my "service engine soon light coming on". I think this is linked to the remote start. Does anyone know this to be common?
Many thanks to all that have helped. I now have a new respect for the technicians out there. Its not as easy as it seams.
