best port/driver direction in trunk
morganpartee
Posted: November 29, 2009 at 10:58 AM / IP Logged
Hey there guys. Fairly new to building for SPL. My plan was to build an enclosure with 4 drivers, and 4 ports, all facing upwards, torwards my trunk lid. Then I got criticism from local shops, and they suggested facing my drivers and ports different directions, such as all backwards.
What is the general consensus?
Thanks- Morganpartee
squires500
Member - Posts: 47
Posted: November 29, 2009 at 6:06 PM / IP Logged
it depends on the shape of the car. you want to try eliminate any interference or echos so imagine a line coming straight out of the subs they will bounce off anything at the same angle they hit it and any soft porous material will deaden the sound.
my favorite position is back left and right of the boot facing the middle of the dash. facing them straight up or down will case lots of echo in a sedan but in a hatch can be awesome as you bypass the back seat and the sound bounces off the back windshield straight at the driver.
there are hundreds of variables that effect where the sub should be located and what direction it should face. the best way to find a good position is to build a small MDF box and place a sub in it (this is known as a test sub) then plug the sub into an amp and chuck it in the boot, sit in the drivers seat and see where the sound is best you can roll the box to most locations and directions just depends how much time you have this also works better with two people.
morganpartee
Posted: November 29, 2009 at 10:41 PM / IP Logged
Thing with right and left facing inwards is phasing issues isn't it?
Or does phase really matter that much if they're dead on facing inward?
Also- It will be in a sedan.
Thanks for the input!
squires500
Member - Posts: 47
Posted: December 06, 2009 at 4:10 AM / IP Logged
phasing is an issue if they face towards one another mine placed there tend to face mostly forward so there is no real phasing issues but given your 4 driver setup its prob best to do the install behind the back seats facing forward
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
