ipod direct connect
vpcom
Member - Posts: 6
Posted: November 29, 2009 at 9:42 PM / IP Logged
The AM-FM radio/CD player in my 2007 VW Passat station wagon does not have an auxilary audio input.  It does, however, have a cable with a 12-pin connector in the gloove compartment for a multi-disk CD player.
Is it possible to connect the audio output of an iPod to this cable in some way and thereby listen to the iPod directly through the radio?  If so, does anyone have the cable pin-out, wiring schematic for doing so?  Any problems?
Don
Platinum - Posts: 13,725
Posted: November 29, 2009 at 9:55 PM / IP Logged
ipod direct connect -- posted image.
Part Number: aPAC-VW2
Category:Auxiliary Input Solutions
Description:Dual Auxiliary Audio Input Interface for Select Volkswagen Vehicles
MSRP: $129.95
Click here for more details
See All Applications
zerepdivad
Silver - Posts: 605
Posted: November 30, 2009 at 11:40 PM / IP Logged
I'd say save yourself the money and get a metra wired fm mod. Those work great from my experiences. ANd a lot cheaper.
A DMM is a beautiful thing.
vpcom
Member - Posts: 6
Posted: December 01, 2009 at 8:50 PM / IP Logged
Thanks for your advice, but what's a metra wired fm module?
Don
Posted: December 01, 2009 at 9:12 PM / IP Logged
An FM modulator is a device that takes a high quality audio signal and broadcasts it onto an FM frequency that is injected into your radio via the antenna cable.  The sound you get wil be only as good as your FM radio can make it.  Granted a wired FM modulator does MUCH better than their wireless equivalent, known as an FM transmitter.  They do still leave some sound quality on the table.  The aux in adapter will allow you to get the best sound possible.
And if you do use the following device you will also need to purchase about 20 dollars worth of antenna adapters
mike2t
Posted: December 02, 2009 at 11:05 AM / IP Logged
You could also use the USASpec PA11VW6.  Gives you ipod control and an AUX input (RCA) for about $139.
http://http://usaspec.com/product.php?Productid=36
Hope this helps, seems there's a lot of options out there.
Mike T
vpcom
Member - Posts: 6
Posted: December 02, 2009 at 12:52 PM / IP Logged
Good suggestions, but the VW dealer from whom I just bought this '07 Passat wagon tells me that removing the radio for direct connect is a lot of work.  They charge more than $100 to do it.
Anyone know if it's possible to connect the headphone output of an iPod directly to the audio-in portion of the cable for a CD changer that's laying lose in the gloove compartment?  Would like to find the schematic on this radio, and hopefully, fashion a connector for input to that unused CD cable.
Thanks for your insight and help!
Don
Posted: December 02, 2009 at 2:23 PM / IP Logged
The radio will not switch to the cd changer unless the cd changer or the aux in piece I linked to (or a similar device) is present.  Any reputable stereo shop will install that device for around 100 dollars.
mike2t
Posted: December 02, 2009 at 3:00 PM / IP Logged
+1
Mike T
vpcom
Member - Posts: 6
Posted: December 02, 2009 at 4:28 PM / IP Logged
Mike T: What do you mean by simply +1?  (Your last response)
Platinum "i am an idiot":  Ya, I thought maybe I could fake out the CD player by putting in a blank disk, thereby opening the circuit for audio input from the lose cable in the gloove compartment.  No luck - the CD player said "disk error" and returned the radio to the previously tuned-in broadcast station.  Smart folk, these German designers.  Guess I'm just a shade-tree mechanic trying to outsmart them and save some bucks for the few times we take long road trips and want to hear books and maybe some music on an iPod in the car.
Thanks for your help
Don
