2002 Dodge Ram Quad 1500
sundial1
Posted: June 07, 2002 at 10:01 PM / IP Logged
Hello,
Does anyone have a wiring diagram for a 2002 Dodge Ram Quad Cab 1500? I'd like to install a remote starter and alarm system. Thank you!!
Platinum - Posts: 12,488
Posted: June 07, 2002 at 11:41 PM / IP Logged
Dodge
Ram Pickup
2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLUE (16 AWG)
Ignition #2:
RED
Ignition  #3:
GREEN & ORANGE (2 WIRES)
Accessory:
BLACK/ WHITE & BLUE (2 WIRES)
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
TAN/RED
AT IGNITION COIL
Parking Lights:
PURPLE / YELLOW
HEADLIGHT SWITCH*
Headlights:
PURPLE / YELLOW
HEADLIGHT SWITCH *
OEM Alarm  Disarm:
LT. GREEN/ ORANGE *****
HARNESS COMING IN FROM DRIVER'S DOOR
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 1.4 K-Ohm Resistor. Headlights Need To See A Ground (-) Through A 1.8 K-Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert.
Dodge
Ram Pickup
2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
BLUE (16 AWG)
Dome  Lights/Superv:
SEE NOTE ***
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ GREEN
DRIVER'S KICK PANEL ****
Power  Unlock:
WHITE/ GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
SEE NOTE ***
Notes:
*** Separate Triggers For Each Door. The Driver's Door Trigger Is Tan (-). The Left Rear Door Trigger Is Tan/Orange (-). Both Wires Can Be Found In The Driver's Kick Panel. The Passenger Front Door Trigger Is Tan/Red (-) And the Passenger Rear Door Trigger Is Tan / YELLOW (-). Both Of These Wires Can Be Found In The Passenger Kick Panel. Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. **** Single Wire Door Lock System. Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor. Diode Isolate One Of The Wires. ***** Requires A Negative Pulse Through A 1.5 K-Ohm Resistor
