1998 gp with viper 5701 trunk release?
kind153
Member - Posts: 8
Posted: December 14, 2009 at 2:02 PM / IP Logged
1998 Pontiac Grand Prix...
Trying to install viper 5701.. done all wires but rear defogger and trunk relay wire.
the12volt.com's diagram says to get it from the switch, but I hear a relay clicking when I push trunk release button on my fob, possibly from the keyless module.
(I don't hear click when pressing button near glove box.)
and a wire from HVAC control controls rear defog? relay?
Does anybody know if I can connect the module directly to the switch wire? (the manual says not to excess 200mA on both defogger and trunk release)
anyone?
Thanks,
t&t tech
Platinum - Posts: 2,622
Posted: December 14, 2009 at 3:16 PM / IP Logged
Have you tested at the respective switches yet?
t&t tech
Posted: December 14, 2009 at 3:20 PM / IP Logged
try this, doesn't have deffoger info though!
kind153
Member - Posts: 8
Posted: December 14, 2009 at 3:31 PM / IP Logged
Thanks for replies, of course I have done the install with the help of the link you gave me.
tested the switch with multimeter, but the switch seems to be just closing the circuit.
I hear a relay clicking left bottom of steering wheel, around BCM, when I click trunk release on my fob.. maybe I can wiggle a wire into its input??
I think it'll really help if I see how the trunk release mechanism diagram looks like...
t&t tech
Posted: December 14, 2009 at 3:35 PM / IP Logged
If the switch is simply closing the circuit, there must be voltage present, unless of course it's data, which i doubt of a vehicle that vintage!
kind153
Member - Posts: 8
Posted: December 14, 2009 at 5:26 PM / IP Logged
Yes, you're right! 14.##v was present with engine running, and 0.00 when it's pressed. How will I know if I can supply max 200mA and still be able to open the thing without damaging my module?
t&t tech
Posted: December 14, 2009 at 5:37 PM / IP Logged
Well that sounds like a negative trigger! The diagram says positive!  Connect the aux wire of your unit to the wire that goes to zero upon pressing the switch, unplug the switch from the circuit and activate the auxillary, if the trunk pops off you go! if not post back!
kind153
Member - Posts: 8
Posted: December 14, 2009 at 6:12 PM / IP Logged
Yeah but,,but,, am I gonna damage the module if it requires more than 200mA?? How can I tell?
t&t tech
Posted: December 14, 2009 at 7:54 PM / IP Logged
No you won't damage anything!
kind153
Member - Posts: 8
Posted: December 15, 2009 at 7:10 AM / IP Logged
Really??
I don't know,,, I like to make sure I got right capacity req before booking it up.. you have any idea how to measure at the switch??
