'06 f350 vsm module location
subieken
Member - Posts: 18
Posted: December 15, 2009 at 5:47 PM / IP Logged
Alot of the tech sheets I find for this vehicle lists doors triggers for the actual latch (not the domelight) at a VSM module. These specific door triggers need to be pulsed to shut off RAP when running remote starter but so far I've only found the driver's one in the door boot.
Does anyone know where this VSM module is from experience or dealer parts info?
Thanks for the help.
Platinum - Posts: 13,670
Posted: December 15, 2009 at 6:20 PM / IP Logged
'06 f350 vsm module location -- posted image.Module 1VSM- LOCATED CENTER OF DASH
'06 f350 vsm module location -- posted image.Module 2PCM-LOCATED UNDER HOOD ON RIGHT SIDE OF FIREWALL(GAS). LOCATED UNDER HOOD LEFT SIDE OF FIREWALL(DIESEL)
subieken
Member - Posts: 18
Posted: December 16, 2009 at 10:21 AM / IP Logged
Oh, I've gotten that lovely piece of information at every source of info for this vehicle and this copy & paste looks like it is from CodeSystems. I'm sorry but I need to know exactly where to put my hands on the box.
Thanks though.
Posted: December 16, 2009 at 10:22 PM / IP Logged
techservices.audiovox.com   but they do own Code Alarm
https://www.the12volt.com/installbay/forum_posts.asp?tid=117773&KW=f350+vsm
subieken
Member - Posts: 18
Posted: December 17, 2009 at 5:12 PM / IP Logged
Well I don't know why I didn't find that in the search but thanks that gives me some more direction.
dvaldez0989
Copper - Posts: 98
Posted: December 17, 2009 at 5:59 PM / IP Logged
you should be able to find all of the door triggers in the passnger kick panel in the wire loom. two of which are running towards the back and two towards the front. if im correct you have to look for them towards the front because in the middle of the loom you will not find the front two doors.
subieken
Member - Posts: 18
Posted: December 18, 2009 at 8:47 AM / IP Logged
I'll check that spot too. Thanks.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
