viper 5901 dome light.
berg9987
Member - Posts: 43
Posted: December 16, 2009 at 12:15 PM / IP Logged
So I'm about ready to install a Viper 5901 and I am going through all the features I want to set up.  I like the option where the Viper turns on the dome light after the ignition is turned off.
I would like to have the dome light stay on for a while when I get into the car (helpfull to get the key in the ignition when its cold and dark, find seatbelts, put on radio faceplate, etc).
I think I know how to do it, I just wanted to make sure I am on the right track or if there is a better way.  Here's my idea:
One of the Aux outputs is connected to a relay pin 85.  Pin 86 is connected to ground.  The door triggers are negative so I need to ground the door trigger wire to turn on the dome light.  As such I splice into this wire and connect it to pin 87 of the relay.  Pin 30 is connected to ground.  Pin 87a is not used.  In the Viper setup Menu 2 - Convenience I set the Aux that I am using to a Timed Output Type (I have a Bitwriter so I can set this time from 1-90 seconds).  Finally I Link the Aux that I am using to Disarm.
This seems to me to be the best way to do this, but if someone has a better one I would like to hear it!
Cheers,
Berg
05gt
Silver - Posts: 628
Posted: December 16, 2009 at 7:06 PM / IP Logged
what kind of car is this, the reason why I ask is because the domelight may turn on when unlocked anyways
berg9987
Member - Posts: 43
Posted: December 16, 2009 at 7:38 PM / IP Logged
It's and 87 Toyota MR2.  It predates the dome light "intellegence".  Am I on the right track for what I want to do?
Cheers,
Berg
mikvot
Gold - Posts: 1,043
Posted: December 16, 2009 at 7:52 PM / IP Logged
I assume you already know that the unit has a domelight output? It will turn the domelight on when you disarm the vehicle. Should give you 20 or 30 seconds...or until the ignition is turned on.
berg9987
Member - Posts: 43
Posted: December 17, 2009 at 8:18 AM / IP Logged
I did know that the unit has a dome light output.  However reading the instructions it only mentions that it will come on for sixty seconds when the ignition is turned off.  I didn't read anywhere about it turning the dome light on when unlocked. I know that most newer cars with keyless ignition will do this, so it makes sense that the Viper will.  If this is the case it will make things a little easier and neater.
Thanks for the quick replies guys.  This will be my first alarm install and I appreciate all the help this site and the people on it have given me.
Cheers,
Berg
berg9987
Member - Posts: 43
Posted: December 17, 2009 at 8:21 AM / IP Logged
Oops... I can't edit my posts.  Above where I wrote "keyless ignition", I meant to write "keyless entry".  My appologies.
Cheers,
Berg
subieken
Member - Posts: 18
Posted: December 17, 2009 at 5:01 PM / IP Logged
Just phone Viper and ask when that domelight output is all activated. They have a tech department for a reason.
berg9987
Member - Posts: 43
Posted: December 17, 2009 at 5:21 PM / IP Logged
Ok, I did call.  The gentleman I spoke with gave me the answer "Usually...." and "That would be my expectation..."  He didn't sound overly confident.
However mikvot says yes, so I am going to run with that.  If it doesn't I can add that relay in later.  Thanks for the help!
Cheers,
Berg
subieken
Member - Posts: 18
Posted: December 17, 2009 at 5:31 PM / IP Logged
I'll check with my distributor tech guys, they install these things so they should have a good idea.
dvaldez0989
Copper - Posts: 98
Posted: December 17, 2009 at 5:44 PM / IP Logged
by any chance did this vehicle ever come with a factory alarm? if so the factory disarm wire will turn the domelight on in some cases. it did with my ford... just thought that might aid in less wiringviper 5901 dome light. -- posted image.
Sunday, September 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
