2007 chrysler, remote starter
ca43528
Posted: December 18, 2009 at 9:48 AM / IP Logged
Hello I am going to attempt my first install of a remote car starter, If anyone has the diagram for a 2007 Chrysler town and country that would be very helpful.. I was also told i need a bypass box i am not sure if i need this the car starter i bought is just a cheap one all it does is start the car. Thanks in advance Carl
monty_77
Copper - Posts: 491
Posted: December 19, 2009 at 12:52 AM / IP Logged
yes you will need a bypass all you will need is a universal transponder if your willing to lose a key or a a bypass that has a transponder in it.
but if i was you i would get something like the PKUCH2X for the bypass it will take care of the transponder and the MUX ignition at the same time.
This will save you the time of having to do relays and resistors and make the installation a lot easier.
you can find them on the web or ebay both.
if you want detail pics and wire chart send an email to weldrite@daktel.com and label the subject with town and country
Chrysler Town and Country 2007
WIRE COLOR LOCATION POL.
Battery 1 PURPLE / Red On Top of BCM Module Positive
Ignition 1 Pink/White Ignition Harness Positive
Starter 1 Yellow (3) Ignition Harness Positive
Starter 2 PURPLE / Brown (4) Ignition Harness Resistor
Accessory 1 Work With Ignition Not Needed
Parklights Positive WHITE/ Brown Driver's Kick Panel Positive
Brake Lights WHITE/ Tan At Brake Switch (Above Brake Pedal) Positive
Horn GREEN/ Purple At Steering Column Negative
Tach Blue/Tan At Multi-Ignition Coil 2 Cyl
Lock PURPLE / Green (1) At BCM Module (Third Connector Down) Negative
Unlock PURPLE / Green (1) At BCM Module (Third Connector Down) (1) Negative
Trunk PURPLE / Tan (2) At BCM Module (Second Connector Down) Negative
OEM Hood Switch PURPLE / Blue At BCM Module (Third Connector Down) [Pin 30] Negative
Disarm PURPLE / Lt Blue (1) At BCM Module (Third Connector Down) Negative
Rearming PURPLE / Lt Blue (1) At BCM Module (Third Connector Down) Negative
Dome Sensor Isolate all door pin with diodes At BCM Module (Third Connector Down) Negative
Trunk Pin PURPLE / Orange At BCM Module (Third Connector Down) Negative
KeySense PURPLE / Brown At Steering Column (4) Resistor
Door Pin FL Purple At BCM Module (Third Connector Down) Negative
Door Pin RL PURPLE / Gray At BCM Module (Third Connector Down) Negative
Door Pin FR PURPLE / White At BCM Module (Third Connector Down) Negative
Door Pin RR Purple / YELLOW At BCM Module (Third Connector Down) Negative
IM/OM Compatibility
- OM-Chrysler-2 (310-907-515) - OM-CUT-II (310-908-500) - IM-Chrysler-2 (310-909-540) - OM-CUT-3 (310-907-516)
- OM-CUT-3 (310-907-516) - IOM-Chrysler-6 (310-908-515) - PKUCH2X - 556C(W) - XK03 - CHDL6+ - DLPKGM - CANMAX400 - DLCH8
- CANMAX400 - DLCH8 & XKEY - - - - - - - - - - - - - - - - - - - - - - - - - - - -
Comments :
Note :This vehicle is equiped with a immobilizer system that needs to be bypassed, (transponder)
(1) If not equiped with Security Lock will be 4,7 Kohms and Unlock 1.8 Kohms on the PURPLE / Green wire, Pin 21.
See picture for the emplacement in the connector. (Third Connector from the Top at BCM).If Equiped with door security,
Unlock is between 7.5K to 10K and Lock is between 1.8K to 2.3K on the PURPLE / Blue on pin 14. it require 2 pulse to unlock the door.
(2) Power trunk is PURPLE / Tan (-), Use 1.5 Kohms resistor if it have the factory alarm. ( Second connector from the Top at the BCM )
Left Slidding door : between 3K to 6.6K ohms, Right Slidding door: between 1.4K to 1.8 Kohms onto the PURPLE / White Wire on the
(Third connector from the Top at BCM). Pin 1. See the BCM Picture into the Diagram Section
(3) For Anti-theft diagram see diagram. If not done that way, you will have a feedback from the ignition after the B.C.M. shut down..
(4) A second Starter pulse is needed on the PURPLE / Brown (KeySensor.) with a negative pulse throu a 180 ohm resistor.
You must use a Relay with a output Programme as Start. (Must Be A Start Pulse Verry Important).
Friday, January 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
