2002 civic si getting radio static
lake207
Member - Posts: 16
Posted: January 03, 2010 at 7:27 PM / IP Logged
I have 2002 civic SI.I just started getting radio static sound when i turn on lights, any about know what could cause of the problem???
but i do have after market radio Clarion MAX385VD.
x1le
Copper - Posts: 171
Posted: January 03, 2010 at 7:35 PM / IP Logged
do you have hid's?
lake207
Member - Posts: 16
Posted: January 03, 2010 at 7:44 PM / IP Logged
yes i do!!!
x1le
Copper - Posts: 171
Posted: January 03, 2010 at 8:25 PM / IP Logged
I'm going to assume they have magnetic ballasts? It's a known issue that they interfere with fm reception...
lake207
Member - Posts: 16
Posted: January 03, 2010 at 8:37 PM / IP Logged
OK is there way to fix it???
x1le
Copper - Posts: 171
Posted: January 03, 2010 at 8:39 PM / IP Logged
Unfortunately the only fix that I know of is to remove them. It doesn't mean you have to get rid of your hid's, just need to use some digital ballasts instead.
Platinum - Posts: 13,725
Posted: January 03, 2010 at 10:22 PM / IP Logged
Adjust the intensity of your dash lights.  Does the noise change pitch in relation to the brightness of the lamps?
lake207
Member - Posts: 16
Posted: January 03, 2010 at 11:09 PM / IP Logged
well that was my other question that if any body know how u adjuster the back light on is head unit? I don't think that will make any different cause soon as i turn on my head light static sound start coming out of the speakers. sound like radio antenna is not getting power losing signal. If i turn on my light first click when my side light turn on not head light i don't get that sound if i turn on fog light sound comeback. I think x1le is right.or may be i should change the ground......let me know that do u think??
Posted: January 04, 2010 at 7:34 AM / IP Logged
It is one of 2 things.  Either the HIDs power supply, or the pulse Width modulated power supply of your dash lights.  Not the display of your radio.  I fugured that if this happened just after the HID install you would have said that in your post.   Do you know how to dim the dash lights?
lake207
Member - Posts: 16
Posted: January 04, 2010 at 10:21 AM / IP Logged
dash light make no different.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
