heated seats in a charger/300/magnum
utaptout
Posted: January 11, 2010 at 10:42 AM / IP Logged
Has anyone hooked up the heated seats in a 2006 Charger, 300, or Magnum to an aux output on a remote start/alarm brain?  Is there a wire at the switch that just requires a negative pulse? Or am I getting into resistors and relays for this one.  I'm also interested in the rear defroster for the same reason.  Thanks for any help anyone can give me.
monty_77
Copper - Posts: 491
Posted: January 13, 2010 at 11:49 AM / IP Logged
Driver Heated Seat Lt.GREEN/ Lt.Blue At The Heated Seat Switch Negative
Passenger Heated Seat Lt.GREEN/ Gray At The Heated Seat Switch Negative
Need a 0.7 second pulse to turn it ON in Hight level, pulse it again it will go to medium, another pulse will turn it OFF
Should not need a relay but if hooking both up to same out put diode isolate them so you don't turn both on when you push one button
utaptout
Posted: January 13, 2010 at 1:03 PM / IP Logged
Thanks a bunch for this information.  Invaluable!!
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
