generic alarm sensor connection
trevors
Copper - Posts: 86
Posted: January 17, 2010 at 5:17 PM / IP Logged
I've a 2008 Scion xB with Scion Security and Glass Break Sensor and a 1990 GSX Eclipse with OE security and no extra sensors.
In neither can I identify a dedicated trigger port for adding sensors.  Am I right in thinking the appropriate technique would be to tap into a door open switch wire (probably driver's), so that if the system is already armed, the alarm will go off (otherwise the signal would be ignored)?
Also, in order to increase security reasonably for both vehicles, what would make sense for each:  Tilt sensors?  Impact sensors?  (Glass break sensor for the Eclipse ?)
Thanks for any insights :) -- Trevor
PS. I've noticed the xB glass break sensor also triggers if anything strikes the car body -- doesn't have to be hard enough to cause damage.
Mike M2
Platinum - Posts: 2,652
Posted: January 17, 2010 at 5:49 PM / IP Logged
The problem with using a door trigger is the interior light will come on when it is triggered. How about a hood pin, is there one?
Mike M2
Tech Manager
CS Dealer Services
trevors
Copper - Posts: 86
Posted: January 17, 2010 at 6:56 PM / IP Logged
Great idea -- the Eclipse definitely has a hood release sensor and the Scion xB almost certainly does also, so if the hood is released with the alarm armed, the alarm will fire.  I'll have to study the schematics to identify the wire.  (Hopefully not a CAN connection on the Scion :().
Thanks very much.  Any quick thoughts on what sensors are valuable to have these days  (tilt? impact? glass break for the Eclipse? other?)
Mike M2
Posted: January 17, 2010 at 8:33 PM / IP Logged
Try the 507 by DEI, it's a tilt sensor that actually works well....
Mike M2
Tech Manager
CS Dealer Services
trevors
Copper - Posts: 86
Posted: January 17, 2010 at 9:03 PM / IP Logged
Thanks much -- I'll look into it :)!
trevors
Copper - Posts: 86
Posted: January 17, 2010 at 9:10 PM / IP Logged
PS. Sorry to bug you yet again, but is there a good shock or glass break sensor I should also look at?  According to DEI, their tilt sensor is a good complement to one.
trevors
Copper - Posts: 86
Posted: January 22, 2010 at 9:03 PM / IP Logged
It turns out the 2008 xB doesn't have hood release detection.  So, I guess I need to install a pin switch somewhere.  However, that leaves me without the alarm trigger wire.  The car does have a Scion Glass Break sensor (GBS ecu), but since neither that nor the Scion Security ECU (TVIP model RS2300 Plus) are standard equipment, I don't know what the Security ECU trigger wire is.  Can anybody give me a hand?
Also, I've identified a number of DEI Sensors I could install:
DEI-504D Shock Sensor
DEI-506T Glass Break Sensor  (for the Eclipse)
DEI-507M Tilt Sensor
DEI-508D Motion Sensor
Any suggestions as to my best bets among them?
Here's the Audiovox info:
      #513391: 2008 SCION XB 4DR SUV
     Audio/Mobile Video
     WIRE                 COLOR     POLARITY      LOCATION
     Battery            LIGHT GREEN  (+)        RADIO HARNESS
     Accesory           GRAY         (+)        RADIO HARNESS
     Ground             BROWN        (-)        RADIO HARNESS
     Illumination       GREEN        (+)        AT RADIO HARNESS
     Power Antenna      ORANGE       (+)        RADIO HARNESS
     LF Speaker (+)     PINK
     LF Speaker (-)     VIOLET
     RF Speaker (+)     LIGHT GREEN
     RF Speaker (-)     BLUE
     LR Speaker (+)     BLACK
     LR Speaker (-)     YELLOW
     RR Speaker (+)     RED
     RR Speaker (-)     WHITE
     Steering Cntrls         OPTIONAL
     Speed Cntrl             OPTIONAL
     Radio Security          YES
     Security
     Battery            WHITE        (+)        IGNITION SWITCH HARNESS
     Ignition 1         GRAY         (+)        IGNITION SWITCH HARNESS
     Starter 1          WHITE        (+)        IGNITION SWITCH HARNESS
     All Door Trigger
               USE EACH DOOR TRIGGER AND DIODE ISOLATE EACH WIRE
     Domelight Super    WHITE        (-)        AT VEHICLE FUSEBOX
     LF Latch           WHITE        (-)        IN PLUG AT VEHICLE FUSEBOX
     RF Latch           BROWN        (-)        IN PLUG AT VEHICLE FUSEBOX
     LR Latch           LIGHT BLUE   (-)        IN HARNESS IN DRIVER KICKPANEL
     RR Latch           LIGHT GREEN  (-)        IN PLUG AT VEHICLE FUSEBOX
     Trunk Trigger      LIGHT GREEN  (-)        AT VEHICLE FUSEBOX
     Parking Lights     GREEN        (+)        AT VEHICLE FUSEBOX
     Convenience
     Headlights-Lo      GRAY         (-)        AT VEHICLE LIGHT SWITCH HARNESS
     Headlights-Hi      PINK         (-)        AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb      GREEN        (+)        AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb      GREEN        (+)        AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb      GREEN        (+)        AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb      GREEN        (+)        AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights   GRAY         (-)        AT VEHICLE HAZARD LIGHT SWITCH
     LF Hazrd Bulb      YELLOW       (+)        AT FRONT LEFT TURNSIGNAL BULB
     RF Hazrd Bulb      BLUE/RED     (+)        AT FRONT RIGHT TURNSIGNAL BULB
     LR Hazrd Bulb      YELLOW       (+)        AT TAIL LIGHT ASSEMBLY
     RR Hazrd Bulb      LIGHT BLUE   (+)        AT TAIL LIGHT ASSEMBLY
     Wipers-Lo          BLACK        (+)        AT VEHICLE WIPER CONTROL SWITCH
     Wipers-Hi          RED          (+)        IGNITION SWITCH HARNESS
     Parking Brake      BLACK        (-)        AT PARKING BRAKE SWITCH
     Trnk Release       ORANGE       (-)        IN HARNESS IN DRIVER KICKPANEL
     Remote Start
     Ignition 2         WHITE        (+)        IGNITION SWITCH HARNESS
     Accessory 1        BLACK        (+)        IGNITION SWITCH HARNESS
     Starter 2          WHITE        (+)        IGNITION SWITCH HARNESS
     Key Sense          BLUE         (-)        AT VEHICLE FUSE BOX
               THIS WIRE WILL DISARM THE FACTORY ALARM WITHOUT UNLOCKING THE DOORS
     Tachometer         GRAY         (AC)       AT DATA LINK CONNECTOR
     Crankshaft Sensor  ORANGE       (AC)       AT ECM MODULE BEHIND GLOVEBOX
     Camshaft Sensor    BLACK        (AC)       AT ECM MODULE BEHIND GLOVEBOX
     Speed Sense        VIOLET       (AC)       AT RADIO HARNESS
               ALSO AT ECU MODULE PIN A8
     Brake Lights       BLUE         (+)        AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights     RED          (+)        AT INTERIOR FUSE BOX - TOP LEFT CORNER
     Horn               LIGHT GREEN  (-)        IGNITION SWITCH HARNESS
               ALSO AT VEHICLE FUSEBOX
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock       PINK         (-)        IN HARNESS IN DRIVER KICKPANEL
               THIS WIRE REQUIRES A DOUBLE PULSE
     PowerLock          LIGHT BLUE   (-)        IN HARNESS IN DRIVER KICKPANEL
     Driver Mtr Unlock  LIGHT BLUE   (AC)       AT DRIVER DOOR LOCK MOTOR
     Driver Mtr Lock    RED          (AC)       AT DRIVER DOOR LOCK MOTOR
     Pas Mtr Unlock     LIGHT BLUE   (AC)       AT PASSENGER DOOR LOCK MOTOR
     Pas Mtr Lock       RED          (AC)       AT PASSENGER DOOR LOCK MOTOR
     LF Window Up       PINK         (REV)      AT DRIVER WINDOW SWITCH
     LF Window Dn       WHITE        (REV)      AT DRIVER WINDOW SWITCH
     RF Window Up       GREEN        (REV)      IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RF Window Dn       BROWN        (REV)      IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Up       RED          (REV)      IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Dn       BLUE         (REV)      IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Up       GREEN        (REV)      IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Dn       BROWN        (REV)      IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Mike M2
Posted: January 23, 2010 at 10:30 AM / IP Logged
Well i'm gonna guess the Scion security is not a factory installed item but a dealer installed item since they are known for buying a basic car and adding accessories when you buy it. This means some mechanic took a plug in alarm system and added it to the car so the unit is actually individual of other car components like the BCM. If this is so, somewhere there is a trigger wire on the security system that comes from the cars triggers. I would suggest a trip to your local Scion dealer and see if you can get a scematic of this alarm. There might actually be a separate input just for your sensors.
Mike M2
Tech Manager
CS Dealer Services
sneakycyber
Silver - Posts: 413
Posted: January 23, 2010 at 1:21 PM / IP Logged
Have you tried Alldata DIY I have gotten all of the wiring schematics for my vehicles from there (the cars I own). If the alarm is a factory option it should be included in the wiring schematics for the vehicle. I currently have a 2002 Kia optima with a factory alarm system, I used my hood pin switch to add an aditional Shock sensor and an audio sensor. The major draw back to using the factory alarm is they generally don't have dual stages. Just google Alldata DIY and you can find the website.
trevors
Copper - Posts: 86
Posted: January 23, 2010 at 2:30 PM / IP Logged
Actually, "Mike M2"'s description is correct.  The Scion xB only has one factory installed option, that being manual Vs automatic transmission.  Everything else is defined as an accessory.  The set of vehicle schematics retrieved from Toyota's Tech website don't appear to cover any of the accessories -- I've had my nose pressed to them.  However, I'll gladly investigate "Alldata DIY" -- thanks for the link :).
Yes, the accessories can either be installed by the dealership or purchased separately and installled later.  I purchased later and installed it myself.  Scion has detailed installation instructions that can be separately downloaded from certain dealer sites, but no shematic information is included either via the kit or download.  I'll try checking with the dealer and emailing Scion to see if they can tell me anything at all about extending the Scion System (eg. lack of  hood release detection seems a significant miss).
The Scion Security ECU inserts into the existing vehicle wiring using what Toyota calls "wire-to-wire" connections -- it opens an existing vehicle harness connection and plugs into both sides -- it has four of them (2pin, 8pin, 14pin, 18pin).  Naturally, the instructions only identify the connectors by location, not by factory designation -- so I can't readily cross-reference them to the vehicle schematics.
So, thanks, I'll see what I can find out.  If you fellows have any thoughts regarding the DEI sensors I listed, I'd really appreciate your input on what might make sense (or if I should be considering something not listed) -- I've zero personal experience with vehicle security.  I've two cars under consideration, and the Eclipse should be much easier since I've detailed security system schematics and a hood pin (I installed and integrated the keyless-entry myself). Here they are again:
