2009 cadillac cts ca5050 w/ ads al ca
phat-focus
Member - Posts: 19
Posted: January 19, 2010 at 8:17 AM / IP Logged
Does anyone have a full tech sheet for this car? Audiovox tech services and AutoPage installation excellence dont provied any remote start information. Really the only thing i need is the brake wire, found everything else. (same as new GM's) The brake switch is so high i can't reach it or even see it.  I ran  search on here and google and couldnt really finda anything either. Thanks in advance for the help.
Driversphere.com
Plainfield/Joliet Illinois.
Flatline till I Flatline
yimke
Copper - Posts: 417
Posted: January 19, 2010 at 9:56 AM / IP Logged
Can you see your BCM? It's easier to grab it there. And usually it only meters with the ignition on.
metz35
Copper - Posts: 458
Posted: January 19, 2010 at 4:17 PM / IP Logged
on the an 06 cts the brake wire was white under the back seat, i dont know if its the same for an 09
Twelvoltz
Platinum - Posts: 2,384
Posted: January 19, 2010 at 5:49 PM / IP Logged
White wire in the driver's kick...or at the IPM (Instrument power module, under passenger side dash behind glove box).
phat-focus
Member - Posts: 19
Posted: January 24, 2010 at 9:47 PM / IP Logged
Got this car coming up, can anyone post a direct wire tech sheet? Just wanna make sure i got everything right before getting into it. Thanks
Driversphere.com
Tuesday, July 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
