2010 Chevrolet Avalanche Alarm/Remote Start Wiring
ezinstaller
Member - Posts: 10
Posted: January 21, 2010 at 10:18 AM / IP Logged
Hi all, just wondering if 2010 Avalanche Remote Start wiring is the same as 2009?
EZ
chev104275
Gold - Posts: 1,427
Posted: January 21, 2010 at 10:50 AM / IP Logged
AVALANCHE   2009 -2010
KEY T-HARNESS IMMOBILIZER
N/A    N/A    PASSKEY 3+, MUST USE INTERFACE MODULE, See NOTE #4
PART   COLOR LOCATION DIAGRAM
12 VOLT CONSTANT   RED / BLACK (X2) 60AMP    @ DASH FUSEBOX, (BLACK 40-Pin Plug (X1) Pins F1 and E3
STARTER PURPLE (+) (NOT for REMOTE START)   @ STARTER or UNDERHOOD FUSEBOX, (BLACK 50-Pin Plug (X2) Pins F1 and F5
STARTER 2 N/A
IGNITION 1 PINK (+)   @ IGNITION SWITCH or BCM, (LT. GREEN Plug) Pin 14, Note #1
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 BROWN (+)   @ IGNITION SWITCH or BCM, (LT. GREEN Plug) Pin 21, Note #1
ACCESSORY /HEATER BLOWER 2
KEYSENSE N/A
PARKING LIGHTS ( - ) LT. BLUE (-)   @ HEADLIGHT SWITCH or BCM, (WHITE Plug) Pin 8, Note #1
PARKING LIGHTS ( + ) BROWN (+) (Left) and BROWN (+) (Right)   @ UNDERHOOD FUSEBOX, (BLACK 30-Pin Plug (X3) Pins A7 and F7
POWER LOCK REQUIRES Door LOCK/UNLOCK Module   USE DLPK-CANBUS MULTI....TO PURCHASE , GOOGLE PART NUMBER AND CLICK SHOPPING
POWER UNLOCK REQUIRES Door LOCK/UNLOCK Module
LOCK MOTOR WIRE GRAY (Reverse Polarity, 5-wire type)   @ DRIVERS KICK PANELor DASH FUSEBOX (BLACK 14-Pin Plug(X3) Pin B4
DOOR TRIGGER GRAY/BLACK (-)   @ DRIVERS WINDOW SWITCH (BROWN 16-Pin PLug) Pin 13
DOMELIGHT SUPERVISION GRAY (+)   @ BCM, (WHITE Plug) Pin 5, Note #1
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN TAN (-)   @ HORN SWITCH or BCM, (BROWN Plug) Pin 18, Note #1
TACH Any wire NOT PINK, PINK/BLACK, or PINK/WHITE (AC)   @ Any Fuel Injector
WAIT TO START LIGHT N/A
BRAKE LT. BLUE/WHITE (+) Note #3   @ BRAKE SWITCH or BCM, (BROWN Plug) Pin 6, Note #1
FACTORY ALARM DISARM   DISARMS with IGNITION AND TRANSPONDER SIGNAL
ANTI-THEFT GM's New PASS KEY 3 +REQUIRES INTERFACE MODULE, NOTE #4
NOTES
Note #1: The BCM, (Body Control Module) is located under the Drivers side Dash and to the
Left of the Steering Column.
Note #2: If a Door Lock/Unlock Module is not available, the Drivers Door LOCK/UNLOCK wires are
PURPLE-TAN (Reverse Polarity 5-wire type) located at the Drivers Window
Switch,(BROWN 16 Pin Plug) Pins 7 and 8. The Passenger Door LOCK/UNLOCK Motors
wires are TAN-GRAY/BLACK(Reverse Polarity 5-wire type) at the Passenge Window
Switch (BROWN 16 Pin Plug) Pins 7 and 8. the REAR Doors Power LOCK/UNLOCK wires
are LT. BLUE (+) and WHITE (-) at the BCM, (GRAY Plug) Pins 7 and 9.
Note #3: The BRAKE wire will only test with the IGNITION Key in the "ON" position.
Note #4: The PASS-KEY III+ System requires a Anti-Theft Bypass Module:
BEST, Part # CANMAX 400 AND Part# XKEYCHGM, does PASSKEY 3, DOOR LOCK and
NO RESISTORS REQUIRED.
Part# XKEYCHGM, does PASSKEY 3 for Remote Starting only, Requires Resistors
Part # DLPK-CANBUS MULTI, Does, Door Locks and PASSKEY 3, but Requires Resistors.
