bypass module for '02 ram 1500?
lins
Member - Posts: 19
Posted: January 25, 2010 at 4:17 PM / IP Logged
I'm still researching what Remote Start to order to replace the CS-310 in my truck now (either Ultra Start or Viper at this point).  According to https://www.the12volt.com/installbay/forum_posts.asp~TID~52897 at the very bottom, I should not need a bypass module as I do not have a 'grey' key.  How can I tell for sure?  Regardless, am I correct in assuming there should already be a bypass module installed and should be ok in splicing in a new system?  I'm 1000 miles away from the nearest installer, so I need all the help you guys can give, thanks!
kanarrjl
Member - Posts: 30
Posted: January 25, 2010 at 5:02 PM / IP Logged
yeah as long as you don't have the grey key you will be fine and yes if it did require a by-pass it would have had one.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
