dei 561t on hummer h3 2006
andrym3
Posted: January 26, 2010 at 1:10 AM / IP Logged
Hello,
I have a problem to crank  Hummer H3, which is already equipped with kit 561T and 2 relay before.
As a result, after changing the battery after about 12 hours, the car does not work .Who can tell me how it will reprogram or reset the module 561T.I have already do a manual 561T install ,unfortunately you haven't the remote control with (*) key
yimke
Copper - Posts: 417
Posted: January 26, 2010 at 9:59 AM / IP Logged
Leave the key on in the IGN position and lights come up on the dash right? If so leave it on in that position for 15 minutes. This will reset the Passkey system.
If it does not light up the dash, the + or - Battery terminal is loose. This is a huge problem on the H3's.
In fact had one the other week where a co-worker installed the remote start and a customer had issues and blamed the install and remote start. So I checked it out and found it out before pulling it in that it was the terminal. Customer still swore it was the remote start and wanted it pulled. I LOL'd at him.
andrym3
Posted: January 26, 2010 at 12:14 PM / IP Logged
Thank you very much, I already tried despite all the same case.
I  mentioned below error on the dash:
4WD transmission
Low fuel
ABS
witnesses Parking led Off ( P)
