passat wagon 98 wiring info
mr.navarro
Posted: January 29, 2010 at 1:47 PM / IP Logged
hi id like to get the wiring info for my passat wagon 98, i look in the database the wiring of the passat 98 doesnt match with of the wagon..also isstated that are two speakers and the wagon get two sets of components.so ill appreciate any info...
Platinum - Posts: 7,827
Posted: February 08, 2010 at 8:12 PM / IP Logged
Here is what Audiovox has for the 98 Passat Wagon
Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  WHITE/ YELLOW  (+)  RADIO HARNESS
 Accesory  WHITE/ RED  (+)  RADIO HARNESS
 Ground  BLACK  (-)  RADIO HARNESS
 Illumination  RED / BLACK  (+)  RADIO HARNESS
 Dimmer  RED  (-)  RADIO HARNESS
 Power Antenna  YELLOW/WHITE  (+)  RADIO HARNESS
 Amp Turn On  YELLOW/WHITE  (+)  RADIO HARNESS
 LF Speaker (+)  WHITE
 LF Speaker (-)  ORANGE
 RF Speaker (+)  YELLOW
 RF Speaker (-)  BROWN
 LR Speaker (+)  RED
 LR Speaker (-)  GREEN
 RR Speaker (+)  BLUE
 RR Speaker (-)  BLACK
 Amp Location  MOUNTED TO BRACKET IN RIGHT SIDE OF TRUNK
 Steering Cntrls  YES
   THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN
APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
 Speed Cntrl  NO
 Radio Security  YES
 Security
 Battery  BROWN AND ORANGE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PINS 12/33 OF 40 PIN PLUG
   PSC/ECU TO THE FAR RIGHT BEHIND GLOVE BOX
 Ignition 1  YELLOW  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 35 OF 40 PIN PLUG
 Starter 1  BLUE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 15 OF 40 PIN PLUG
 All Door Trigger  BLACK/ WHITE  (-)  AT PLUG TOP OF FUSEBOX
   TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS
 Domelight Super  BLUE  (-)  BECU PIN 2 OF 10 PIN PLUG
 LF Latch  RED  (-)  BECU PIN 14 OF A 16 PIN PLUG
   BECU IS ATTACHED TO PASSENGER FUSE BOX BEHIND GLOVE BOX
 RF Latch  RED  (-)  BECU PIN 23 OF A 28 PIN PLUG
 LR Latch  GREEN  (-)  BECU PIN 11 OF A 28 PIN PLUG
 RR Latch  BLUE  (-)  BECU PIN 16 OF A 16 PIN PLUG
 Trunk Trigger  RED  (-)  BECU PIN 11 OF A 16 PIN PLUG * SEE NOTES
 Hood Trigger  WHITE/ BLUE  (-)  HOOD PIN SWITCH UNDER HOOD
 Alarm Disarm  ARMS WITH LOCKS
   FIRST PULSE DISARMS SECOND PULSE UNLOCKS
 Alarm Arm  DISARMS WITH UNLOCK
 Parking Lights  GREEN  (+)  AT THE BACK OF PARKING LIGHT UNDER HOOD
 Low Crr Pk Lights  RED / YELLOW  (-)  LIGHT SWITCH HARNESS
 Convenience
 Headlights-Lo  BLUE/RED  (-)  IGNITION SWITCH HARNESS
 Headlights-Hi  ORANGE / WHITE  (-)  LIGHT SWITCH HARNESS
 LF Pk Lt Bulb  RED / BLACK  (+)  AT FRONT LEFT PARKING LIGHT
 RF Pk Lt Bulb  RED / BLACK  (+)  AT FRONT RIGHT PARKING LIGHT
 LR Pk Lt Bulb  RED / BLACK  (+)  AT REAR LEFT PARKING LIGHT
 RR Pk Lt Bulb  RED / BLACK  (+)  AT REAR RIGHT PARKING LIGHT
 Wipers-Lo  BLUE / YELLOW  (-)  IGNITION SWITCH HARNESS
 Wipers-Hi  BLUE / YELLOW  (-)  IN HARNESS UNDER LEFT SIDE OF DASH
 Parking Brake  GREEN/ RED  (-)  AT PRAKING BRAKE SWITCH
   MAY ALSO BE GREEN / WHITE
 Trnk Release  LIGHT GREEN  (-)  BECU PIN 13
 Remote Start
 Ignition 2  LIGHT BLUE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN34 OF 40 PIN PLUG
 Accessory 1  GREEN  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 11 OF 40PIN PLUG
 Starter 2  LIGHT BLUE  (+)  PSC/ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 17 OF 40 PIN PLUG
 Anti-Theft Type  UNIVERSAL TRANSPONDER
 Anti-Theft Descript  THE KEY SENDS A RF SIGNAL TO THE BCM THROUGH A ANTENNA AROUND THE KEY CYLINDER
 Key Sense  BLUE/WHITE  (-)  IGNITION SWITCH HARNESS
 Neutral Safety  GREEN / WHITE  (-)  AT GEAR SELECTOR SWITCH
 Tachometer  WHITE  (AC)  PIN 9 AT THE DATA CONNECTOR
 Speed Sense  PURPLE  (AC)  ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG
 Low Crr. Pk Lights  RED / YELLOW  (-)  LIGHT SWITCH HARNESS
 Brake Lights  RED / BLACK  (+)  BRAKE PEDAL
 Reverse Lights  RED  (+)  ECU PIN13
 Horn  YELLOW  (-)  STEERING COLUMN HARNESS
 Rear Defrost  BROWN / YELLOW
   MAY BE BROWN ON SOME MODELS
 Modules
 WIRE  LOCATION
 Please select another category
 Doorlocks/Windows
 Power Unlock  LIGHT GREEN  (-)  POWER MASTER SWITCH IN DRIVERS DOOR
 PowerLock  PINK  (-)  POWER MASTER SWITCH IN DRIVERS DOOR
   REQUIRES DOUBLE PUSLE
 Driver Mtr Unlock  RED  (REV)  ECU IN DRIVERS DOOR
 Driver Mtr Lock  GREEN  (REV)  ECU IN DRIVERS DOOR
 Pas Mtr Unlock  RED  (REV)  ECU IN PASSENGER DOOR
 LF Window Up  RED / YELLOW  (REV)  DRIVERS DOOR SWITCH
 LF Window Dn  RED / BLUE  (REV)  DRIVERS DOOR SWITCH
 RF Window Up  BLUE / YELLOW  (REV)  DRIVER KICK PANEL
 RF Window Dn  BLUE  (REV)  DRIVER KICK PANEL
  Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy,
completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility
for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any
circuitry with the proper test equipment prior to installation.
mr.navarro
Posted: February 20, 2010 at 9:33 PM / IP Logged
thanks for the info i let you know if it works later...
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
