sub box
bighit05
Posted: February 11, 2010 at 3:05 AM / IP Logged
hey guys,
i have a dual 2ohm alpine type R 15" sub and at the moment its in a ported box which i dont think is the right size so im looking at building a different box, its going into a suzuki baleno hatchback im looking to build a ported box tuned to around 30-34hz i hear thats a good number
what dimensions and what type of port would sound best with this sub setup ?
ianarian
Copper - Posts: 516
Posted: February 11, 2010 at 5:55 AM / IP Logged
A friend of mine has that sub rockin louder than anyone else I've heard or seen. His box has a gross of 4.5 ft3, 1.44 ft3 of vent space, which is about 50si. Your vehicle probably wont allow for that so post the dimensions of the space you are going to allocate for the enclosure. The amp type can have a effect on the performance so that may be a good thing to mention too. "Best Sound" is opinion based only. Do you want to hear or feel you sub? J. Reed probably will have the numbers you need based off the info gathered.
This is what I do for FUN!
bighit05
Posted: February 16, 2010 at 5:06 AM / IP Logged
im more looking to feel the bass, ive got a fusion am2000d (the 1000watt rms at 1ohm amp) and the box i have at the moment is around 3.56 cubic feet from memory and its about as big as will fit in my car.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
