friend fixing to use 18 gauge sub wiring
mustanglife
Member - Posts: 27
Posted: February 11, 2010 at 11:17 AM / IP Logged
A buddy of mine is cheap and has alot of 18 to 20 gauge speaker wire laying around. Not sure exactly what kind of watts his amp will be pushing but probaly around 500 watts rms, maybe 800 watts rms. Hes going to be wiring his two 12 subwoofers with 18 guage wiring into a 2ohm load. Tell me what to tell him on the reason he needs 12 gauge wiring?
Josh
2003 Modded Mustang GT
yimke
Copper - Posts: 417
Posted: February 11, 2010 at 11:25 AM / IP Logged
He's fine. It is minimal SPL difference. Even though 12ga would be preferable. It depends if it is ACTUALLY 18ga wire or "labeled" as 18ga but actually 22 ga.
awdeclipse
Copper - Posts: 285
Posted: February 11, 2010 at 11:42 AM / IP Logged
Was he planning on doubling it up to "increase the gauge" too or just running a single wire?
mustanglife
Member - Posts: 27
Posted: February 11, 2010 at 12:01 PM / IP Logged
No just regular single wire.
smtgolf
Member - Posts: 44
Posted: February 11, 2010 at 12:31 PM / IP Logged
If the speaker wire run is short (a few feet), it should work. The longer the wire, the bigger the impact. It can show up in SPL as mentioned before.
Then again, people will do what they do no matter what. Threaten him that it could heat up his equipment too much due to resistance and it will all melt (figure the cost of 12-14 ga versus new amp/sub). Not that it would work (wink-wink) on him anyway........
mustanglife
Member - Posts: 27
Posted: February 11, 2010 at 12:56 PM / IP Logged
Will do. I'm running 12 guage sub wiring and only have about 2 feet from the box to amp. I almost think I wasted my money now, lol.
smtgolf
Member - Posts: 44
Posted: February 11, 2010 at 1:13 PM / IP Logged
Nah, you're just maximizing the power transfer and eliminating a possible SPL reduction. I run 16 ga (real 16 ga that is) for 300w RMS. But the wire is 4 feet. If that changed (more watts, longer run), I would consider 14 g. So far it hasn't been an issue.
haemphyst
Platinum - Posts: 5,054
Posted: February 11, 2010 at 2:25 PM / IP Logged
800WRMS through 20 feet of 18g wire into a 2 ohm load equals a loss of 1.04dB. Anything less than 20 feet, and he'll never hear the loss, period.
He'll be fine.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
