car alarm, 99 civic dx
cantstopthis
Member - Posts: 6
Posted: March 10, 2010 at 1:13 PM / IP Logged
My friend just installed a viper 7900 in his car. he got to works and everything so he installed his friends viper 7900 into a 99 civic dx, and it wont work. I did some basic voltage reading and it seems as if everything is connected good. the alarm wont respond at all. we installed his known good workin module and all we could get was a call on the pager. Also the remote they have doesnt seem to be the original, i cant seem to program it. Anyhelp would be awesome guys thanks a bunch!
Posted: March 10, 2010 at 5:27 PM / IP Logged
Do a check list of what's needed, for instance, manual transmission? Clutch switch? Factory transponder immobiliser, is it by-passed? Tach learned etc. Correctly grounded? Have you metered between the power and ground lines? Try another remote? Is the antenna plugged in correctly?
If you don't know what's been done we can't help you!
Test the R/S by placing car in neutral and grounding the WHITE/ blue wire twice if auto if manual does it do the safe start procedure?
Have you programmed the remotes for either auto or manual transmission?
cantstopthis
Member - Posts: 6
Posted: March 10, 2010 at 11:26 PM / IP Logged
i apoligize for the lack of information ... Its a manual transmission,not sure if it has Factory transponder immobiliser or if its by-passed? Tach learned-does it need this even if im not going to use remote star? It is correctly grounded and has power; i did voltage drops and they all came out good? i need to Try another remote? im sure the antenna plugged in correctly. not sure how to program the remotes for either auto or manual transmission.
Posted: March 11, 2010 at 2:28 AM / IP Logged
If not R/S ignore many of my comments such as tach, bypass, clutch switch, none required, just change the remote, it's faulty.
cantstopthis
Member - Posts: 6
Posted: March 11, 2010 at 12:30 PM / IP Logged
ok, and how do i program it? i cant seem to find a way to program the remote ... thanks for all your help howie
