hid problem can someone figure this out
fede2022
Posted: March 10, 2010 at 10:56 PM / IP Logged
Hi i have a set of bi-xenon H4 6K hid lights. I have a problem that only one light will turn on. The weird thing is though sometimes its the driver side that doesn't turn on and some times its the passenger side that doesn't turn on.Once and a while they'll both turn on but that's rare. its as if it only has enough power to turn on one. but my battery is new though. What do you think it could it be?
Thanks in advance!
anonymous1
Copper - Posts: 151
Posted: March 11, 2010 at 12:37 AM / IP Logged
Bad connections
Do you have a volt meter? If so you could check the supply voltage and see if the one that doesnt light up is actually getting any voltage to the pack at the time.
And the one that does light up, check the voltage there too while it's on.
It could be that which ever lights up grabs enough voltage and current that it cuases a sudden drop and the other one blinks out.
Does this happen when the car is running?
fede2022
Posted: March 11, 2010 at 5:17 PM / IP Logged
Should one of the grounds be going to the battery? i thought that that could be the problem but im not sure.
Yea it does it while its running too. If one doesnt light it makes a noise from the ballast. its like zzzt zzzt zzzt. lol
Thanks for the reply.
fede2022
Posted: March 12, 2010 at 10:49 PM / IP Logged
Just today now they both stopped working! :S
jeremytravis
Copper - Posts: 62
Posted: March 13, 2010 at 3:25 PM / IP Logged
What kind of car?
**advanced mecp certified
Moderator - Posts: 12,488
Posted: March 13, 2010 at 9:21 PM / IP Logged
Meter your ground from the battery to the point of ground on the HID kit. You want to be a close to 0 as possible.
anonymous1
Copper - Posts: 151
Posted: March 14, 2010 at 12:48 PM / IP Logged
True true . .
OP, where exactly is the wiring for these grounded?
Do you have inline fuses? If so, do the ends of the fuse appear to have any marks or discoloration?
Are there any crimp type connections used in the wiring?
Where are you getting your 12v from?
Can you post pics of this and put them on imageshack?
Thx
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
