2010 dodge ram, alarm wiring
qdaddy
Copper - Posts: 133
Posted: March 16, 2010 at 9:56 AM / IP Logged
Does anyone hav alarm wiring for 2010 dodge ram. I know locks are in passenger front door but don't remember resistance or park lights
thnX in advance
Platinum - Posts: 7,783
Posted: March 16, 2010 at 7:27 PM / IP Logged
If its the same as a 2009, it is Violet/Light Green at module in passanger door, with 330 ohms for lock and 100 ohms for unlock.
Parking lights is (-) thru 1k resistor at the light switch.  Should be White wire at Pin 1 of a Black 10 pin plug.
Can't find a listing for 2010's.
campinout
Member - Posts: 16
Posted: August 19, 2010 at 10:18 AM / IP Logged
its not the same as an 09. u can find info on directechs. if you use relays, be ready to use about 7 of them....i use a adsalca and it does all the work for you. good luck.
Old School Funkster
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
