1999 chevy express xpresskit solex bypass
charlespierce
Posted: March 17, 2010 at 3:40 PM / IP Logged
I need some assistance on wiring a bypass expresskit Xk06 for my 1999 chevy express 3500 van.I am trying to figure out how to wire it so my remote start will work. I have a vision guard 8000 alarm system installed already. I just need help on wiring the bypass.
blanx218
Silver - Posts: 654
Posted: March 17, 2010 at 11:04 PM / IP Logged
couple questions. what version firmware are you using on your bypass? is it installed and not working correctly? the correct firmware is PLXR for your van. different firmwares have different wiring instructions on the XK06. if you do have the correct firmware i would check your connections, reset the bypass and reprogram it
charlespierce
Posted: March 18, 2010 at 12:31 PM / IP Logged
Thanks, I do have the wrong firmware. Do you know where I can find the PLXR version diagram? I've looked on directed and can't seem to locate it.
kgerry
Platinum - Posts: 3,455
Posted: March 18, 2010 at 2:47 PM / IP Logged
unit will need to be flashed with the correct firmware if PLXR is not the default firmware..... wiring diagrams per firmware are available on bypasskits site....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Platinum - Posts: 7,827
Posted: March 18, 2010 at 3:07 PM / IP Logged
Here is a link to the DEI Web site:     http://www.xpresskit.com/VehicleCompatibility.aspx?v=362&ps=1
Wednesday, October 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
