what if they only have 1 key
toyotaman78
Member - Posts: 10
Posted: March 20, 2010 at 12:05 PM / IP Logged
I am installing an autopage remote start using an im05 on a 2010 f150. Customer states that they only have one key, can this work? Can u just program the same key twice?
Platinum - Posts: 7,783
Posted: March 20, 2010 at 3:44 PM / IP Logged
Nope.  If you are using 5.PKTI Ver 1.02 firmware, you need 2 working, non clone keys to program the module.  You can't use the same key twice.
toyotaman78
Member - Posts: 10
Posted: March 20, 2010 at 4:19 PM / IP Logged
does anybody make a module for that vehicle that requires 1 key
tedmond
Gold - Posts: 4,610
Posted: March 20, 2010 at 5:18 PM / IP Logged
unfortunatly no.
your best bet is to go to a locksmith, buy a blank and have it programmed. take that newly made key and use a 556u/key in box bypass.
Ted
Compustar Expert
beegbie
Copper - Posts: 341
Posted: March 20, 2010 at 5:35 PM / IP Logged
ADS can do it.
tedmond
Gold - Posts: 4,610
Posted: March 20, 2010 at 5:49 PM / IP Logged
from what im aware of. any ford or mazda and select few chryslers require 2 keys to program any bypass.
Ted
Compustar Expert
jeremytravis
Copper - Posts: 62
Posted: March 20, 2010 at 10:37 PM / IP Logged
Yep, I have always needed two keys.
**advanced mecp certified
Chris Luongo
Platinum - Posts: 3,746
Posted: March 21, 2010 at 10:26 AM / IP Logged
ADS (idatalink.com) can do it.
You need not only their module, but also their uploader cable to flash the module.
Also, have your customer leave the truck with you for the day. You have to connect to the truck first, then connect the module back to your computer and upload the information to ADS, and then (usually within a few hours) they can send you a special firmware for your module, to complete the installation.
tedmond
Gold - Posts: 4,610
Posted: March 21, 2010 at 7:47 PM / IP Logged
thanks chris, so what kregs mentioned to me was infact correct.
thanks to bth for the info. im trying to find out if fortin pieces can do that,
Ted
Compustar Expert
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
