compustar cold weather issues
sonyw810
Member - Posts: 6
Posted: March 27, 2010 at 10:14 AM / IP Logged
Compustar RF-Pw1g4-900fm not starting in cold weather
Vehicle type: 2007 Toyota matrix; 2007 Toyota Rav4, 2008 Toyota Siena, 2007 Ford F150.
Problem: after sitting all day or all night In cold weather (below 10 degrees fahrenheit)  the remote starter will no longer respond. No lock/unlock control, no start function. But vehicle starts fine off key. Then if you let it warm up and try the remote start again it works fine.
Tried calling tech support they advised us to move/replace the antenna which we have done and it didnt help. Replaced the Blade-TB which didnt help.
mike08401
Member - Posts: 33
Posted: March 27, 2010 at 12:02 PM / IP Logged
I'm experiance the same thing not all the time but some time too when it's too cold my RF-P2WSS also will not start. will not lock or unlock. but after few minute it will works normal again. and because happen not too many times so I did not bother
tedmond
Gold - Posts: 4,610
Posted: March 27, 2010 at 7:36 PM / IP Logged
there are problems with some of the CM6000 antennas. if the unit still engages but does not start, most likely you missed a second start wire on the toyotas.
Ted
Compustar Expert
Friday, May 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
