idatalink doorlock issue
x1le
Copper - Posts: 171
Posted: April 09, 2010 at 12:11 AM / IP Logged
so I did my first remote start on a manual transmission vehicle tonight, my own car! Installed a viper 5901 into my 2001 pt cruiser and used an idatalink ads-dl for the bypass.
Everything works correctly except my doorlocks. When I hit unlock/disarm on the remote, all 4 doors will lock and then only the driver will unlock. When I hit lock/arm, the security system arms, but nothing happens with the doors. Any ideas? I connected doorlocks through the ads-dl as written in the manual.
Too tired to think right now and figured I'd ask you guys before I go and take a crack back at it tomorrow. Thanks.
Platinum - Posts: 7,783
Posted: April 09, 2010 at 5:54 AM / IP Logged
Just a couple of thoughts and things to check that might be redundant....
The iDatalink ADS DL should be flashed with ADS DL CH6 ver  1.7 firmware.  I would wire it up in W2W mode and set it to Standard Mode.  If you have already set it up this way, then a factory reset, mode set and re-program is in order.
The iDatalink guide says it's the Type 3 install for your car.  The modules Yellow analog output wire goes to the cars "one wire door lock" wire.  I would double check that I was on the correct wire by testing it with a 3 k resistor ( lock ) and a 7.2 k resistor ( unlock ) to ground just to be should I found the correct wire in the harness coming into the kick panel from the door.
I have installed iDatalink on some Dodges that do the Drivers door priority unlock routine automatically, just like the factory FOB.  ( First unlock press just does the drivers door, second unlock press ( within 3 seconds ) does the rest of the doors.)
Mike M2
Platinum - Posts: 2,652
Posted: April 09, 2010 at 6:20 AM / IP Logged
I believe the doors must be closed for the doors to lock also...
Mike M2
Tech Manager
CS Dealer Services
x1le
Copper - Posts: 171
Posted: April 09, 2010 at 7:33 AM / IP Logged
appreciate the help! yes, I have it flashed and set up w2w. like I said, all other funtions work like door triggers, tach, bypass, etc. I'm thinking I probably snagged the wrong doorlock wire, I'll definitely go double check. Thanks!
Posted: April 09, 2010 at 8:22 AM / IP Logged
Another thought because of the Viper 5901 and its'  + / -  lock outputs..........
In W2W mode, the Green wire from the Vipers 3 Pin Door harmess is the Lock wire and is attached to the iDatalink GREEN/ Black lock wire.  The iDatalink module is looking for a Type B (-) lock signal.  The Vipers Blue wire from that same harness is the UnLock wire.
x1le
Copper - Posts: 171
Posted: April 09, 2010 at 9:42 AM / IP Logged
I did have the wrong doorlock wire! I had originally grabbed a WHITE/ green along a harness in the driver kick. After looking @ several different diagrams, it said it's straight from the door. I ended up pulling the fusebox and right behind it is a harness that had the correct wire.
thanks for the help!
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
