2004 freestar navigation
Brian78675
Member - Posts: 6
Posted: April 10, 2010 at 4:08 AM / IP Logged
Does anyone have a wiring diagram/colors for  parking brake, reverse light, and vss for the freestar?  Thanks
Brian78675
Member - Posts: 6
Posted: April 13, 2010 at 4:02 AM / IP Logged
I got the information I was looking for and decided to post for others to use. The following is for 2005 Freestar, but should work for 2004-2006.
Stereo/Navigation Wiring - 2005 Freestar
Function Vehicle Color +/- Location
12v at all times LG/VT + Pin 1 Radio 24 pin plug
12v ignition on GY/YE + Pin 2 Radio 24 pin plug
Ground BK/LG - Pin 13 Radio 24 pin plug
Radio Illumination LG/RD + Pin 3 Radio 24 pin plug
Power Antenna YE/BK + Pin 5 Radio 24 pin plug
Left Front Speaker OG/LG + Pin 8 Radio 24 pin plug
LB/WH - Pin 21 Radio 24 pin plug
Left Rear Speaker GY/LB + Pin 9 Radio 24 pin plug
TN/YE - Pin 22 Radio 24 pin plug
Right Rear Speaker OG/RD + Pin 10 Radio 24 pin plug
BN/PK - Pin 23 Radio 24 pin plug
Right Front Speaker WH/LG + Pin 11 Radio 24 pin plug
DG/OG - Pin 12 Radio 24 pin plug
Speed Sense Wh/OG pulse Pin 14 Radio 24 pin Plug
Steering wheel controls LB/RD Pin 18 Radio 24 pin plug
Parking Brake RD/YE - Pin 50 Black 52 Pin connector at SJB
Notes: The SJB (Smart Junction Box) is in the Driver kick panel behind fuse panel.
Reverse Lamp WH/YE + Pin 13 Gray 52 pin connector at SJB
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
