1998 gmc c/k overhead compass
Brandenbmx
Member - Posts: 28
Posted: April 17, 2010 at 8:06 PM / IP Logged
I am working on a 1998 gmc  fullsize pickup, it has a overhead console. These trucks console has a block off plate where in the suburbans has a rear air control. The s-10 Blazers have a similar overhead console with a digital compass and Temp readout in this spot.  After getting one from a donar 98 blazer I found it fits perfect. I also got the harness and Ambiant air temp sensor off the blazer. I have the wiring diag too. I have everything figured out except the VSS wire.
The Vss is listed in the Vehicle wire diag lists driver kick but no color given just a pin out given. Both are 4k pulse on blazer and full size so it should work fine. But where can find this vss wire? Dont some of the gm's have a vss in radio harness? They adjust the volume by speed at the radio?
Thanks.
sparkie
Platinum - Posts: 2,061
Posted: April 18, 2010 at 10:39 AM / IP Logged
If it is at the radio, it will be the dark GREEN / WHITE wire in the main radio plug.
sparky
Brandenbmx
Member - Posts: 28
Posted: April 18, 2010 at 2:15 PM / IP Logged
Yeah,  There is a dk green with white stripe in the radio plug. It is a form of a vss but not exactly the vss 4k pulse wire. It steps up voltage at 30 mph 60 mph and so on.  It works but its slower than the true vss wire.  For some reason the Temp on the display uses the vss to update its info...  I got the compass calibrated and working but the ambaint air temp isnt correct or extremely slow because of the vss.
sparkie
Posted: April 18, 2010 at 2:47 PM / IP Logged
The VSS wire circuit is the same between both vehicles and both are 4000 PPM. The temp sensor has nothing to do with the VSS. The sensors are slow to respond and need to be located in the correct location to be accurate.
sparky
Brandenbmx
Member - Posts: 28
Posted: April 18, 2010 at 8:30 PM / IP Logged
I mounted the ambiant air temp sensor in the exact location as it was on the blazer.  I know that they are both 4k vss. But the vss wire at the radio is not a true vss circut. It is motified for the raido auto volume control, I pulled the gm diag from alldata pro and it only increases voltage in incraments of 10mph, so the vss at the radio is not a true vss.  also IT IS nessess the VSS tells the computer when you are not moving so don't update the temperature.  I tested both ways. The Temp NEVER CHANGES without the VSS without power cycling the unit. With true vss wire,  (wifes gtp used as test because its easy to get at)  and air temp sensor in vent to test temp change , it changes immediately with temp change. Her car has digital read out for the climate control and it is perfectly accurate and changes with the climate display.   So this leads me to belive because I am not using a true VSS  in the 98 gmc it is much slower updating . About 10 times slower to be exact. LOL     I am going to pull the cluster sometime this week and run my wire to the vss wire that runs the speedo, That has to be a true VSS.
Any other ideas?
Platinum - Posts: 13,726
Posted: April 18, 2010 at 8:44 PM / IP Logged
1998 gmc c/k overhead compass -- posted image. Speed Sense GREEN / WHITE 4000 (AC) DRIV FRT QTR BLK 24 PIN CONN POS 3
Brandenbmx
Member - Posts: 28
Posted: April 18, 2010 at 9:18 PM / IP Logged
Could not find it in that location.  I dont know what a front quater is but I looked  in the front driver kick and there is a black 24 pin but no GREEN/ wht at pin 3, no GREEN/ wht in harness.
Posted: April 18, 2010 at 9:38 PM / IP Logged
Drivers side Front Quarter panel.  I would look under the hood
Posted: April 18, 2010 at 9:41 PM / IP Logged
If the vehicle has Anti-Lock brakes, the wire will be at the ABS box.  It will probably be mounted to the fender.  The brake line will come from the brake reservoir and goto the ABS module.  Look for a plug with that wire color at the ABS module.
Brandenbmx
Member - Posts: 28
Posted: April 19, 2010 at 9:25 AM / IP Logged
Cool Ill check it out.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
