sub wiring
hastey2411
Member - Posts: 11
Posted: April 30, 2010 at 5:40 PM / IP Logged
This is all going in my boat keep in mind!!
Hey here is what I've got.. Two dvc 2ohm cvx subs two svc 4ohm Sony subs and a 1500 rms @ 1 ohm mtx mono.
The cvx subs are going in a .9 qubic feet sealed inclosure each on the deck of the boat and Sony subs in a bandpass in the hull of the boat..
So here is my questions for this setup!! I want to run the cvx subs in paralell with the coils in series to get a 2ohm load. The sony subs in paralell to get a 2ohm load. All on the one mtx amp.
Will this give the amp a 1ohm load?
And will tha Sony subs get half the power because they ate 4ohm? If so that's what I want..
Can it even be wired like that?
Any sugestions or ideas feel free!!!
chris
Platinum - Posts: 13,725
Posted: April 30, 2010 at 6:42 PM / IP Logged
Yes the amp will see a 1 ohm load.  Each speaker will recieve the same amount of power.  As far as the amp and Ohms Law are concerned, each is a 4 ohm driver.
hastey2411
Member - Posts: 11
Posted: April 30, 2010 at 7:15 PM / IP Logged
Thanks this setup should work nice then.. Is there any way to send more power to the kicker cvx subs than the sony subs in this setup?
Posted: April 30, 2010 at 7:40 PM / IP Logged
Wire the sony's in series for an 8 ohm load on those 2.
hastey2411
Member - Posts: 11
Posted: April 30, 2010 at 7:45 PM / IP Logged
Sweet I was thinking that but what will the load be on the amp then? My biggest worry was that it wasn't gonna work together I see it will
thanks
chris
Posted: April 30, 2010 at 7:46 PM / IP Logged
The amp will then see a 1.6 ohm load
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
