Posted: April 15, 2003 at 12:03 PM / IP Logged
Posted: April 15, 2003 at 10:36 PM / IP Logged
Monday, May 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
The main reason I often suggest using an external line output converter is that for some vehicle's the factory output voltage is higher than what the aftermarket amplifier can handle, even on its high level inputs. The external converters usually do a little better job of handling that higher power, but they're not required for all vehicles. Might want to check out this
