fi btl setup
blackdynamite33
Member - Posts: 9
Posted: June 17, 2010 at 8:54 PM / IP Logged
So I am looking at getting an FI BTL 18" (2000 watts rms) fully loaded dual 1ohm and a power acoustik bamf5000 rated at 3.2kw at 1 ohm. I know I am going to have to upgrade the alternator, but how many amps should it be without requiring multiple batteries? I also know i will need to upgrade the big 3 and the battery(Im looking at an optima yellowtop d34). This system won't be played while the car is off so i dont beleive i need more than one battery. Also, i have about 13cu ft of trunk space so i want to mount the sub in a box close to that size, tuned to 32-34hz.i would like to hit somewhere close to 140 or 150db. any recommendations, tips, or ideas concerning this setup? I'm fairly new to car audio installs and i want to make sure i do it right. thanks in advance.
topinstaller200
Copper - Posts: 164
Posted: June 17, 2010 at 9:17 PM / IP Logged
Whats the year make and model of your car? What is RMS wattage of you Amp?
blackdynamite33
Member - Posts: 9
Posted: June 17, 2010 at 10:28 PM / IP Logged
2001 hyundai tiburon. and the amp im looking at getting is rated at 1.7kw at 4ohms 2.5kw at 2ohms and 3.5 at 1ohm. Power Acoustik BAMF5500 (mono). unless you can recommend a better amp for this setup.
icearrow6
Copper - Posts: 497
Posted: June 18, 2010 at 1:41 PM / IP Logged
Audioque AQ3500D.1
It will move the BTL without a problem.
blackdynamite33
Member - Posts: 9
Posted: June 18, 2010 at 11:21 PM / IP Logged
alright, i changed my mind. i dont want to put TOOO much money into this car. im planning on buying a new next year. so i think ima just buy two fi btl 12's. Will a 200 amp alternator, 1 optima yellowtop and the audioque aq3500d.1 with big three upgraded be enough to power the system without any problems?
blackdynamite33
Member - Posts: 9
Posted: June 19, 2010 at 12:24 AM / IP Logged
oh yeh. they will be fully loaded. not sure about 1 or 2 ohms yet
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
